Old 02-03-2008, 09:08 PM   #1
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
coolant temp sensor, S13/S14.......are they the same?
I am going to replace the coolant temp sensor on my S14 SR motor and I was wondering if the one for the S13 SR is the same. Everywhere I have seen them for sale only states the S13 one as an option. I would assume that they are the same, but I don't like buying things based off of assumptions. Any help would be great appreciated.
khilgers is offline   Reply With Quote
Old 02-03-2008, 09:13 PM   #2
S14DB
AFC #1
S14DB's Avatar
Use a B14 SR sensor IIRC.
Old 02-03-2008, 09:21 PM   #3
khilgers
I was hoping there was another coolant temp sensor I could use. B14 was the 95-99 sentra/200sx correct?
Old 02-03-2008, 09:22 PM   #4
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
depends which one....ecu CTS or gauge CTS
garagelu is offline   Reply With Quote
Old 02-03-2008, 09:24 PM   #5
khilgers
Sorry I should have specified.
I NEED THE ECU COOLANT TEMP SENSOR
Old 02-03-2008, 10:26 PM   #6
khilgers
anyone else? Time for sleep I'll check for more info in the morning.
Old 02-03-2008, 10:47 PM   #7
njd07
njd07's Avatar
njd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfection
Send a message via MSN to njd07
just curious...why does yours need replacing??? is your check engine light on? or you just replacing to get better mileage?
njd07 is offline   Reply With Quote
Old 02-03-2008, 10:52 PM   #8
khilgers
I'm replacing it to try to figure out if my fan controller is dead or if my CTS is bad.
Old 02-03-2008, 10:54 PM   #9
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
If the ECU CTS is dead, your car will run like shit once the engine is warm.
CLICK HERE!!!
Old 02-04-2008, 03:07 PM   #10
khilgers
Are you 100% sure. Can anyone else chime in on this?
Old 02-04-2008, 03:18 PM   #11
garagelu
Trader Rating: (60)
oh yea your car will run crazy rich if your CTS is bad. Your ecu will think you are in closed loop still and just keep dumping fuel.
And no I dont think the s13 CTS is the same is S14. I know that the USDM 91 sentra se-r CTS is the same as the s13 sr20 CTS. So you may want to try the B14 CTS as mentioned above. That should be the right CTS for you.
Go to the nissan dealer and find out if the B13 and B14 CTS have the same part number. Make sure they know its the se-r. This should give you a better clue.
Old 02-04-2008, 03:59 PM   #12
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
use one from a s14 KA.
JadeCantDrift Blogspot
i need tires is offline   Reply With Quote
Old 02-04-2008, 04:02 PM   #13
projectRDM
projectRDM's Avatar
True, a bad CTS will signal the ECU to run the cold fuel map all the time, even when warm, running extremely rich and tripping to O2 to go into open loop. You can also test it by unplugging it, if the OEM electric fan is still wired in, the fan will turn on immediately, no matter the actual temp.
Is yours a red plug, or blue plug?
FORMERLY R240NA
Old 02-04-2008, 08:10 PM   #14
buku_points
buku_points's Avatar
buku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfection
since you guys are one the cts subject, i have a 98 s14 obd II,it threw a engine light for the cts, i changed it but still throws the light, it runs super rich,i have no mods and get worse mileage than a truck. what else could it be?
buku_points is offline   Reply With Quote
Old 02-04-2008, 08:26 PM   #15
S14DB
AFC #1
S14DB's Avatar
The connector? Thermostat?
Old 02-04-2008, 09:06 PM   #16
buku_points
both are still good, but when i plug the connector into the cts thats when it boggs and smells like gas bad but if i unplug it doesnt smell as bad
Old 02-04-2008, 09:11 PM   #17
Jtuned S13
Jtuned S13 is on the path to ruinJtuned S13 is on the path to ruin
omg im a noob wtf is cts???
Jtuned S13 is offline   Reply With Quote
Old 02-04-2008, 09:14 PM   #18
khilgers
coolant temp sensor
