Old 02-12-2008, 11:41 AM   #1
kazuma
kazuma is an unknown quantity at this point
s14 air bag ecu Q
Was wondering does the ecu control the airbags or do they have their own seperate controller? Reason is Iam going ka-t and will be using a s13 ecu with a conversion harness so I wanted to know if it will effect the airbags or not.
kazuma is offline   Reply With Quote
Old 02-12-2008, 11:44 AM   #2
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
why do you want to use a s13 ecu and a conversion harness?? i thought the s14 ecu would do just fine...
but i dont think the air bag is controlled by the ecu.
i need tires is offline   Reply With Quote
Old 02-12-2008, 11:45 AM   #3
kazuma
certain s14 ecu are very hard to chip and cost alot more, I already have a s13 ka-t with a chipped ecu so Iam just going to use that.
Old 02-12-2008, 11:48 AM   #4
i need tires
ah ok! just weird to me cause we have a tuner here that can tune any KA ecu for $300
perhaps you should look a little further into seeing if that can be done for you also. mainly being i hate wiring lol
Old 02-12-2008, 11:44 AM   #5
cws14
cws14 is an unknown quantity at this point
There is a seperate ecu under the rear seat. You can use a standalone ecu and the airbags will still work.
cws14 is offline   Reply With Quote
