Old 02-13-2008, 08:23 AM   #1
Captain_Ron80
Captain_Ron80's Avatar
Captain_Ron80 is making a name for him/her selfCaptain_Ron80 is making a name for him/her self
Does this sound like my Coolant Temp Sensor needs replaced?
I've been posting a few questions lately and I appreciate everyones willingness to help. I am just working on cleaning up a few things on the ol' S13 as far as operation goes. Since my blacktop swap my oem temp guage doesn't work properly. When I first started the engine it functioned only once or twice intermittently... Now I get nearly nothing from it. Every once in awhile it will creep up just above the 1st line but that is it. I know it is not the guage because I have 3 clusters and they all have this exact symptom. I am planning on installing aftermarket although I am a bit anal and just want the one in the cluster to work. I have burped the radiator a few times and i'm pretty sure that all the bubbles are gone. A few questions...
1) Does it sound like the coolant temp sensor needs to be replaced?
2) I read that late model blacktops may use a different sensor then early... Confirm?
3) USDM replacement?
Thanks in advance...
Ron
Captain_Ron80 is offline   Reply With Quote
Old 02-13-2008, 09:45 AM   #2
cotbu
cotbu's Avatar
Thermistor or wiring, try wiggling the plug, or check the contacts.
Old 02-13-2008, 10:01 AM   #3
Captain_Ron80
Coolant temp sensor needs replacing?
It was just a straight up swap... I don't believe it is wiring... especially seeings how it is functioning somewhat. At least that is how it is making sense to me. Thermistor is a new term for me. Can you elaborate?
Old 02-13-2008, 12:23 PM   #4
cotbu
cotbu's Avatar
Thermistor
It's the sensor by the coolant temp sensor, it's for the stock temp gauge.
Old 02-14-2008, 08:36 AM   #5
Captain_Ron80
Thermistor
Oh, I know what you are referring to. I'll check it out this weekend. Thanks!
Ron
Old 02-14-2008, 09:10 AM   #6
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
Invest in an aftermarket gauge for coolant. They are a lot more accurate thatn the stock gauge.
thelinja is offline   Reply With Quote
Old 02-14-2008, 08:40 PM   #7
Captain_Ron80
I am going to install one soon... but like my original post said I am just anal about everything working the way it should!
Old 02-14-2008, 09:34 AM   #8
txrxs
txrxs's Avatar
txrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfection
Aftermarket radiator? If so, unplug your fans and let it run for a bit. See if the gauge gets to operating temp?
DRIFTINDY
txrxs is offline   Reply With Quote
Old 02-14-2008, 08:44 PM   #9
Captain_Ron80
Actually I do... It's a visteon aluminum with dual electric. Will that keep the operating engine temperature so low to where the guage won't even move? I guess the couple times I have seen it move (just barely above the 1st line) was when I was in the boost pretty hard. Not a bad suggestion though to unplug the fan though. I'll also try that.
