Old 02-18-2008, 11:53 PM   #1
onesicklambo
onesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant future
SR20det-Ground strap on back- SPARKING!
So my car wasnt starting for some odd reason... but while looking in the engine bay during cranking I noticed a spark! On the back of the block, on the head theres a factory small braided stainless wire bolted on, and a connector at the other end. Its kinda by where all the coil packs ground. I had my friend hold it to ground while I cranked it...and it burnt him and started smoking. WTF! that much power from a ground/....
So is the head not grounded correctly? If i attach it to ground i am afraid it will start smoking again. My block is gorunded with 4gauge wire from the starter bolt right to frame..with a good ground. Should I reground the head??? anytone had this problem? Do I have a short?
onesicklambo is offline   Reply With Quote
Old 02-19-2008, 12:00 AM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
LMAO i cant help it but you burnt your buddy hahahahaha lol
ok yes you should ground the head but ground it properly and make if you ground the wiring shave a little paint off where you are grounding it so that its grounded right.
o yea check your grounding to your starter. sometimes its loose cause mine happens to be like that sometimes so i check it often enough. and reground it.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 02-19-2008, 06:33 PM   #3
rappadan
rappadan is an unknown quantity at this point
add more grounds, and check all the grounds you already have
rappadan is offline   Reply With Quote
Old 02-19-2008, 10:05 PM   #4
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
bad connections make sparks, and make heat
fix yo grounds son!
also make sure the plastic alternator grommet isn't cracked/broken. it's the little piece of plastic that separates the charge stud from the alternator housing (which is grounded to your motor by all the bracketry etc.) jiggle your charge wire.
and i concur with add more grounds. from the battery to the chassis and chassis to motor.
Dave =]
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 02-20-2008, 12:02 AM   #5
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
Yeah foreal.
Check your battery terminals too, and start ohming shit out. Grounds like that don't just spark up for no reason
Anto is offline   Reply With Quote
Old 02-20-2008, 12:11 AM   #6
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
LOL. You burnt your buddy because
1. your other grounds are bad
2. There was prob. just as much current going through the ground as the power wire.
gotta240 is offline   Reply With Quote
