Old 02-26-2008, 11:01 AM   #1
Wes_s13
Wes_s13 is a jewel in the roughWes_s13 is a jewel in the roughWes_s13 is a jewel in the roughWes_s13 is a jewel in the roughWes_s13 is a jewel in the roughWes_s13 is a jewel in the roughWes_s13 is a jewel in the rough
Send a message via AIM to Wes_s13
Questions About Spec-V Brembo Calipers on S13!
I've tried searching everywhere for answers but found nothing. Was wondering if the sentra spec-v brembo calipers will bolt onto an s13 like the z32 calipers do. They look to be same as the z32 but im not sure. If they are direct bolt on, which rotors do i use? I heard you have to use maxima rotors but that seems awkward. If anyone can vouch for that, id appreciate it also. Would i also need to use a z32 mbc since these are 4 piston brakes? Also would the brembo lines fit onto s13? Thanks in advance guys..
Quick notes:
Sentra Spec-V brembo calipers direct bolt on onto 5 lug s13??
What rotors to use ?
Brembo brake lines fit onto s13? Or do i need new lines? If so, where do i find em?
THanks again
Smoke tires , Not drugs.
Wes_s13 is offline   Reply With Quote
Old 02-26-2008, 11:53 AM   #2
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
u can use the spec-v rotors, its a 4-lug rotor so it will fit a stock s13 hub just fine. If you have 5-lug just get the rotors re-drilled for 5-lug.
Lines you can either use the stock lines from the spec-v brembo or buy s/s lines for the spec-v. The Z32 conversion lines might work, like they do on the Z33 Brembos, just need to verify the thread pitch.
eek is offline   Reply With Quote
Old 02-26-2008, 11:56 AM   #3
gunluvS14
gunluvS14's Avatar
gunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura about
i don't see the real benefit from it, IIRC, they are only 22mm thick ... i think.
http://www.zilvia.net/f/image.php?type=sigpic&userid=45706&dateline=118722  3315
gunluvS14 is offline   Reply With Quote
Old 02-26-2008, 11:57 AM   #4
eek
Trader Rating: (29)
only benefit from it is looks and direct upgrade from stock w/out having to switch to 5-lug. Z32 uses a thicker rotor for sure.
Old 02-26-2008, 02:11 PM   #5
Wes_s13
oh well they look nice..and they are 4 piston brakes..better than stock
Old 02-26-2008, 02:11 PM   #6
Wes_s13
should i use a z32 master brake cylinder?
Old 02-26-2008, 07:08 PM   #7
eek
Trader Rating: (29)
I would highly suggest it, unless you want a mushy pedal. Also, if you are going for the COMPLETE BREMBO look on a budget *giggles* remember the STI rear brembo calipers work (BOLT ON) if you have a COMPLETE Z32 rear brake setup. Hence you will need the z32 rear drum setup, and rotors and ebrake lines. Just slap on sti brembo calipers and bam instant bling factor.
Old 03-15-2008, 11:31 PM   #8
brewster240
brewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond repute
Send a message via AIM to brewster240
adding this for people who search in the future:
the regular spec v brakes are 280mmx22mm.
the brembo optional rotors are not the same specs, however i do not know exactly what the specs are, thats what im searching for now.
if you look around, the standard rotors and the brembo optional rotors have different part numbers.
brewster240 is offline   Reply With Quote
Old 03-16-2008, 12:45 PM   #9
brewster240
ok so what i have found is that the optional brembo package rotors are
300mm x 22m
i will confirm once i have them in my possesion.
