![]() ![]() ![]() ![]() Feedback Score: 0 reviews
All motor 240 ideas.
I am thinking about keeping the ka24e and going the all motor route...
I figure the obvious place to start is the 5 speed swap. But I want to get a higher geared rear end. The car will not be a daily driver so just about anything goes for the build. Questions: What is the highest geared setup I can use? And can you point me into a direction to find some info on it? Do the KA24E and KA24DE use the same exhaust manifold flanges? |
ka24e and ka24de uses different exhaust manifold flanges.
If you want high output off the ka24e - contact robello racing in nor cal. If you want high output off the ka24de - look up greaser (freshalloy member) |
The highest all motor KA I've heard of are the ITA engines that make 200hp. There is one guy on here who built a KA like that too, it shoots massive flames and runs on race gas I think? They are expensive and you need to really need to know how to tune them.
If you really want "all motor" best bet is to just make it easy and get an LT/LS series V8...or just limit your goals to 140hp and keep the KA. |
![]() Join Date: Jul 2006
Here's the 200 whp ka24de that is shooting flames
[ame]http://www.youtube.com/watch?v=MfQ4eA626kM[/ame] I think he was not quite at 200 on that vid though, but he is now. His nick is Greaser_, he is on some other nissan forums
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
If all he could get is 200hp on race gas the he wasn't doing it right! The SCCA GT2 and 3 cars use KA's and the single cam's make over 250hp! Besides if you wanna go monster you can make more than that because you are not limited by any rulebook. Brian Crower has a 2.65 litre stroker kit for the KADE's. That combined with a great head (porting, BIG valves, etc...), ITB's, high compression (like 12 to 14 to 1 high), race gas, cams, and a great ECU should be able to put more than 300hp and torque to the pavement.
#7 | |
![]() Join Date: Oct 2006
i think its pretty easy to shoot flames when your exhaust is only 2 and a half feet long
The gap between MORE and ENOUGH never closes. ![]() DriftUtah | UtahNissans | MySpace | I <3 Drifting. ![]() Secret Society |
2xx,xxx don't know specific mileage but i know it has to be tired and ready for a build. I have a Neon that is going to be the turbo project so i want an all motor build with a 240 and would be happy with a mid 13 second time. don't care about power levels. just want a nice powered nice looking 240. because a neon will never look nice.
I never dynod my NA KAE motor, but it was much faster than my 180whp/ftlb KAET. Had 12.7:1 CR, custom cam grind care of PDM on Nismo Blank, P&P head, Port matched, balanced, straight exhaust, and ECU work, reworked intake.
As has been said its not cheap but its worth it. Its even better becuase most people thow out great motors when they swap to the faactory turbo'd ones. Buy an FSM and become friends with a machinist. |
![]() Join Date: Jun 2004
I would swap an S2000 Engine in before building a KA.
[email protected] |
#14 |
I guess you hate torque or something then! There is absolutely NOTHING at all wrong with a N/A KA build. For the cost of swapping a stock s2k motor I could build a KA that would spank the hell out of an s2k motor! Shit s2k's barely pull on me on the straights with my stock KADE.
#15 | |
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Cervasa on 240SXF made 187 with:
Exedy Stage 2 Clutch Fidanza 11lbs FW P & P w/ 5 Angle Valve Job by Cosworth Ferrera 1mm OS Int/Exh Valves Ferrera Dual Springs and Retainers Bc 272 Cams Xcessive Intake Mani Hotshot Intake Dc Header Catco 3" RS*R Ex MAg Cometic 91mm HG ARP Main and Rod Bolts Wiseco 90.5mm 10.5:1 C/R Pistons Eagle Rods UR Crank Pulley Sard FPR Walboro 255lph Pump JWT Cam Gears Thermal Intake Gasket DeatschWerks 450cc injectors Deso Iridum Plugs Magnacor Wires Crank Scrapper
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got ![]() |
#17 |
Gotta dyno for your KADE?
[email protected] |
#18 |
I dynoed it a few years ago when it was absolutely bone stock and it had about 140whp and 135 tq. It should have somewhere around 150-160whp and 135-145 tq, but the compression is a bit low and it seems to have lost it's oompth, if you know what I mean. I don't really understand why this is significant to this thread though.
#19 |
Because I would swap an S2000 Engine into a S13 before building a KA.
Thats why. Greasers car is Totally radical. But, he spent money on his KA build. It wasn't cheap. ITB's and a standalone? No, not cheapening out at all. Its just after that much money, I would rather just put an S2000 engine in.
[email protected] |
#20 |
But the built KA would cost around the same amount of money as swapping in the stock s2k motor and the KA would have way more torque and most likely more horsepower too. I think Carrol Shelby said it best "horsepower sells cars, torque wins races". That is the 100% TRUTH right there. The s2k motor would rev better and have a better top end, but the brute force torque of the KA would rocket the car off the corners.
#23 | |
uhh but the stock f20c would actually be reliable.... |
#24 | |
Why wouldn't a moderately built and well tuned KA be reliable? KA's are known to be pretty bulletproof! |
#25 | ||
#26 | |
KA24DE with cams + AEM + Headers + Exhaust/ Intake will make more usable power and torque than an S2000 engine, in fact stock for stock on a road course if you know what you are doing straigh line is almost the same. ps. The 300 HP NA KAs are rated as Brake output, so they are more like 250whp, and they run on 110 or alchohal only. Compression ratio is sky high. About the highest you can get in a street car is aroun 180-200whp. Even Greaser has to run 100 octane or higher all the time or his setup pings like crazy.
Like Me on FaceBook ![]() |
#27 | |
![]() Join Date: Apr 2003
Allowing the cams to advance or retard is pretty much what allows these 11.3:1 Compression engines to use 91 octane without getting a crap load of knock and ping, and to satisfy smog emissions. I'm cheaping out on my build, the grand total will be some where around $2300 in parts, and a crap load of labor. Right now my engines compression is in the shitter and my engine makes 162 WHP, I don't think its that difficult to make relatively 38 additional whp and stay smog legal using PDM cams, truck main caps, an extruded manifold and 300cc injectors. I mean the reality is I've already made over 30 WHP from stock with a cheap SAFC and bolt ons, it really can't be that difficult.
#28 | |
![]() Join Date: Mar 2007
what about the beautifully light and precise feeling f20c transmission! so many people talk motor swap for motor swap but fail to even include some of the best aspects of certain swaps, the tranny! LS1 is great becuase the 6speed T56 is bulletproof and has great close ratios. the f20c is great because the 6speed is super slick and amazingly precise and quick shifting, its a wonderful piece of automotive machinery. and now back to your regularly scheduled N/A KA thread, lol
cardomain.com/id/LS1T56FC = my crazy ls1 v8 rx7 = sold |
#29 | |
And he's running 89.5mm Bore, my bad
#30 |
How much torque does a built ka make?
[email protected] |
