Old 04-24-2008, 05:24 PM   #1
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
What's the quickest way to switch wheels if you have sideskirts?
Hahaha what an embarrassing question, but how do all of you who have sideskirts switch wheels at drift days?
Do you actually take the time to remove the skirts, jack up the car, mount new wheels, lower car, and put the skirts back on?
That's what I do but I'm curious if there's an easier way that doesn't involve removing the skirts.
I know some people drive the rear up on ramps and jack it up by the diff, but I don't think I could fit ramps or a jack under the rear bumper.
Basically I'm just trying to get an idea of what others do, if it has to be the "hard" way then so be it, but if there's some kind of trick then please tell me.
And no, drifting without sideskirts is not an option! Haha.
Old 04-24-2008, 05:34 PM   #2
Fries
Fries's Avatar
Matej, don't worry. I'll be at the drift events I'll simply pick the car up while you change the wheelz. DUH! (Good question imo)
Old 04-24-2008, 05:37 PM   #3
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
Take two 2x4's. Place under rear wheels. Drive up onto 2x4's.
Jack from the diff and OBVIOUSLY use jack stands.
Fast, simple, cheap.
gotta240 is offline   Reply With Quote
Old 04-24-2008, 05:40 PM   #4
awesomenick
awesomenick's Avatar
Trader Rating: (33)
awesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfection
Feedback Score: 33 reviews
Drive on uneven slopes to lift a wheel. haha.
awesomenick is offline   Reply With Quote
Old 04-24-2008, 06:50 PM   #5
McRussellPants
rofl.
nobody uses jackstands to change wheels.
I don't even use them changing wheels on the trailer.
you're not going under the car.
you aren't gonna die if you don't absolutely suck at cars.
use the tow hook on the rear bumper. its easy to get a jack that far under.
McRussellPants is offline   Reply With Quote
Old 04-24-2008, 05:40 PM   #6
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
yeah or if you want to be hardcore like me, for the rear just jack from your tow hook on the passenger side. or buy a very low pro jack, i use both methods
Slip Gypsies Blog
not sure if you realize this
Old 04-24-2008, 05:44 PM   #7
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
I just use wooden planks that are like 5 inch wide and about 2 inches high.
The ramp is about 5 feet long and I have another one that I nailed on top of it that's about 1 and 1/2 feet long.
Then I make an angle at both ends and that's how I drive up on it to get enough space to jack up the car.
I jack up the diff on the rear side and in the front I jack it up at the subframe thing behind the oil pan.
Or you could just jack it up from the tow hooks.
Old 04-24-2008, 05:47 PM   #8
sil40drift
sil40drift is on a distinguished road
Someone posted a very good idea.
if you have two jacks, You can raise the car slightly by jacking up the tow hook. At which point you can then slide a second jack under the diff and proceed to jack the car up safely.
sil40drift is offline   Reply With Quote
Old 04-24-2008, 05:54 PM   #9
azndoc
azndoc's Avatar
Trader Rating: (47)
Or............
You can save yourself the trouble of bringing three jacks with you and just drive your car up on the ramps. Then jack it up from the bottom.
Geez people I believe with close to 20 events I've got this figured out.
Old 04-24-2008, 05:57 PM   #10
Fries
Fries's Avatar
mastah~
Smart. I used to use stock jack to lift side up then use a real(?) jack to lift car, but I think I'll just bring some 2x4's!
Old 04-24-2008, 06:20 PM   #11
TougeLabs
TougeLabs's Avatar
TougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to behold
Send a message via AIM to TougeLabs
How about pneumatic jacks ?K sport makes them i wanna see someone toss them on
TougeLabs is offline   Reply With Quote
Old 04-24-2008, 06:28 PM   #12
Flybert
Tow hook or ramps or a combination of both.
Old 04-24-2008, 06:29 PM   #13
punxva
punxva's Avatar
Trader Rating: (31)
yeah the ksports are beefy as hell, if i had a total track car, i'd be rocking those bad boys, plus they arent too expensive either roughly $330.00, and they are lightweight too, only about 5lbs...
FTW
Slip Gypsies Blog
Old 04-24-2008, 09:54 PM   #14
SW20Racer
SW20Racer's Avatar
SW20Racer is close to perfectionSW20Racer is close to perfectionSW20Racer is close to perfectionSW20Racer is close to perfectionSW20Racer is close to perfectionSW20Racer is close to perfectionSW20Racer is close to perfectionSW20Racer is close to perfectionSW20Racer is close to perfectionSW20Racer is close to perfectionSW20Racer is close to perfection
FTW
quit being suching a cock tease and give me mor einfo on what/where these are. i cant read the decal.
SW20Racer is offline   Reply With Quote
Old 04-24-2008, 09:55 PM   #15
d r i f t swift
d r i f t swift's Avatar
d r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the rough
http://www.ksportusa.com/asp/pneumat...roduct_id=pa01
rip bobby.. you will be missed..
d r i f t swift is offline   Reply With Quote
Old 04-24-2008, 06:51 PM   #16
illvialuver
illvialuver's Avatar
shit i wold use those jacks on a daily driven/ track car. so its 300 something for each? so about 1200 gets you the ability to not have to worry about this shit ever?
so can you ingage these like speed racer and jump over shit?
Old 04-24-2008, 06:52 PM   #17
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
oh!
jack on the rear tow hook and hope it holds!
http://bhworld.wordpress.com/
Old 04-24-2008, 07:04 PM   #18
Phlip
Yes, I look like that
Phlip's Avatar
Jack from tow hooks or drive up on a 2x4.
Get it off those tow hooks FAST.
Weirdo
And I write too!
Old 04-24-2008, 07:26 PM   #19
Mi Beardo es Loco
Mi Beardo es Loco's Avatar
Location: A place where boob jobs ruined the best thing about being a fat chick.
Mi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfection
they DO sell low profile jacks.
Originally Posted by JVD
I'm a street thug straight outta compton...
Any of you guys watch gay porn?
Mi Beardo es Loco is offline   Reply With Quote
Old 04-24-2008, 07:27 PM   #20
awesomenick
Trader Rating: (33)
Probably not low enough for Matej or others....
Old 04-24-2008, 07:53 PM   #21
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
Ya, still not low enough for the most part.
JVD is offline   Reply With Quote
Old 04-24-2008, 08:05 PM   #22
projectRDM
projectRDM's Avatar
Or buy low profile ramps. There used to be an Ebay seller who had them for $49 a pair. Lightweight, ABS plastic, easy to carry and store in the car.
FORMERLY R240NA
Old 04-24-2008, 08:08 PM   #23
silviaguy240
silviaguy240's Avatar
buy a 8ft 2x10. cut into two 3ft pieces and two 1ft pieces, angle cut the edges at w/e degree you want, screw together. boom 4inch ramps for under $7.
Old 04-24-2008, 08:19 PM   #24
thatdrifterguy
thatdrifterguy's Avatar
thatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to behold
maybe cut a hole under the skirt so that a jack can fit? idk.
ive been driving onto 2x4s
thatdrifterguy is offline   Reply With Quote
Old 04-24-2008, 08:30 PM   #25
d*star180
d*star180's Avatar
d*star180 has a reputation beyond reputed*star180 has a reputation beyond reputed*star180 has a reputation beyond reputed*star180 has a reputation beyond reputed*star180 has a reputation beyond reputed*star180 has a reputation beyond reputed*star180 has a reputation beyond reputed*star180 has a reputation beyond reputed*star180 has a reputation beyond reputed*star180 has a reputation beyond reputed*star180 has a reputation beyond repute
Super low profile jack right under the diff.
Or regular jack right behind/underish the rear bumper on the support.
Works great.
IG: DARKSQUADNIGHTMARE
DARK*SQUAD. SINCE 2005.
d*star180 is offline   Reply With Quote
Old 04-24-2008, 08:40 PM   #26
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
A little bit more expensive than 2x4s but works great! Lightweight, too.
http://performance.yoparts.com/tomio.../i-130482.aspx
Old 04-24-2008, 08:41 PM   #27
2fast240
2fast240 has a reputation beyond repute2fast240 has a reputation beyond repute2fast240 has a reputation beyond repute2fast240 has a reputation beyond repute2fast240 has a reputation beyond repute2fast240 has a reputation beyond repute2fast240 has a reputation beyond repute2fast240 has a reputation beyond repute2fast240 has a reputation beyond repute2fast240 has a reputation beyond repute2fast240 has a reputation beyond repute
I always use the tow hooks. Works everytime. Low pro jack on the diff is good too.
RESPECT MAH AUTHORITAH!!!!!
2fast240 is offline   Reply With Quote
Old 04-24-2008, 08:54 PM   #28
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
hydro jack with ramps FTMFWN....
if the ramps dont fit under skirt on side, put behind rear wheels and back up on to them.
INeedNewTires is offline   Reply With Quote
Old 04-24-2008, 09:04 PM   #29
Matej
Trader Rating: (39)
Hmm tow hook sounds like risky bizniz, I'd be worried about bending something, I'm going to try 2x4's since that's the second cheapest method haha.
Old 04-24-2008, 09:07 PM   #30
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
IIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfection
Feedback Score: 22 reviews
Air Jacks.
...But I use the tow hook all the time, it works.
Just get the jack nice and centered
IIIXziuR is offline   Reply With Quote
