![]() After my car sits for a day or two, after starting it there is a strong fuel smell when I first turn it on. If it sits for a week or more without me starting its about 10x stronger after first turning it on, almost intoxicating. After driving for a while the smell is gone. I get a bit of the strong oder when I first turn it on in the morning. I know KAs tend to run rich, but I think something is up. I don't believe its a leak. What can it be?
Car is a stock 95 auto S14. Thanks in advance.
![]() Join Date: May 2006
Yup, cabin smell probably = fuel tank o-ring. Cheap to replace at a $tealer$hip.
![]() Join Date: Sep 2006
As suggested the o ring that goes around the fuel pump where it goes into the tank.
I once had a bad oring around one of my injectors for a couple days and it would leak a little gas so I would get the smell inside the cabin, but only when then air was on. If it smells like gas as soon as you are getting in though, then it isn't what my problem was...
1997 240sx SE 1998 Frontier SE 1990 240sx Coupe - Sold 1992 Talon Tsi - Sold |
#8 | |
Thanks a lot guys! I'll check that out.
#10 | |
had this happen twice. first time was due to normal wear on an old car and needed replaced. second time just needed to retighten the clamp. |
![]() Join Date: Apr 2004
I found the most problems on the big O-ring between the lid and the tank, not the small o-ring.
When you get gas, do you feel the tank depressurising when you open the filler cap or is there nothing at all? It should feel like opening a soda bottle. If not, you have a leak in the fuel tank lid. |
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
check the lines, and the 0 ring. mine started as a small smell, then got worse, turns out my line had a small hole and squirted all over. got a new line and new o ring, no problems now! |
#13 | |
Which line was it for you?
#14 |
the feed line, it was cracked to shit and then i guess sprung a leak. i replaced it with new efi hose and made sure the clamps were all good and tight.
fyi i did have to drop the tank, i did it when it was almost on Empty. it made it easier to get the rubber hose attached up to the chassis hard line. total time maybe 1.5 hours i did it myself, with help under an hour easy. open the trunk/hatch pull the pump cover off and look into it, you can do a visual check on the hoses. |
#16 | |
honestly wasnt that bad to do really |
#17 |
AFC #1
![]() Join Date: Oct 2003
The S14 doesn't have that shitty O ring like the S13. It's got a screw on cap on the top of the tank.
I was thinking your evap purge is screwed up but then you said you had a 95 and some had the charcoal canister in the engine bay. Try opening the gas cap one day before you drive and let the pressure bleed off the tank. This is all I can think of it being cause you say it builds up if you don't drive and it only leaks when you start it up. Which is when the evap system purges. If it were a leak in the lines the fuel would evaporate over time and the smell would be less then day to day running. But the evap system would be sealed all the time and build up more gasses over time. so when you drive it after a longer time the smell is worse. Basically the evap is purging into the air and not the intake manifold like it should. Usually the evap is behind the rear passenger wheel on the S14. But, some OBDI 95's had the S13 setup in the bay. Which do you have?
#18 |
Hmmm, that may be it. I have the black canister in the engine bay (car is OBDI). Now that I think about it one of the lines that goes from the canister cracked so I took it off (the one that goes under the throttle body). So what shall I do?
#19 |
![]() Join Date: Oct 2007
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
if its in the cabin, %100 sure its a hose, o-rings dont get replaced untill removed. fuel hoses get brittle and leak, check by squeezing and check for cracks or leaks. replace and drive.
Daily Driven |
#20 |
AFC #1
Yeah thats the purge line that opens up to purge the vapors into the intake manifold. Now it's purging into the engine bay and you are smelling that in your vents. Buy some line at the parts store and hook it back up. You probably have a vac leak too if you didn't cap the intake manifold.
#21 |
GNNR... How did everything work out? I have the same issue. I'm going to have to check my lines aswell. I get the same stong smell of fuel in the cabin. I filled my tank lastnight. I drove about 38 miles to work today and burn 1/4 of a tank. WTF. Stock Redtop SR at 10lbs. I drove my step dads 4Runner the same distance and got WWAAAYYY better gas milage.
#22 |
Hmm, funny you mention it I was planning on working on my car this weekend, I'll address that issue tomorrow. Gotta buy the hose. But like I said I think its emissions related (since KA has a bunch of that crap) your problem sounds like a fuel leak.
#23 |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
quick question....ive replaced my Oring...but i also wanna replace th eother 2 lines the feed and return lines...how hard are they to change...
i just wanna change the 18+ year hoses with new ones ![]()
![]() ![]() PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r ![]() |
#24 |
I just had a fuel situation myself... I have a 95 as well, and I kept smelling gasoline for a couple days. I checked and checked and couldn't find anything. Finally found that it was a hairline fracture in my tank. The crack was on an area of the tank that couldn't be reached, so I couldn't just repair it with that epoxy stuff. Many don't know this, I learned the hard way, but to get our tanks out to replace them requires removing the entire rear K-frame, exhaust, and drive shaft... I hated my life... not to mention a junk yard tank cost $210.00
#25 |
not giving a fuck
WTF!?!?!??! ![]() was it made of gold and full of 105 octane ![]()
#26 |
Nope, believe it or not... I searched everywhere. Best price I could find. It wasn't even local, I had to ship it in from Georgia to Mobile, Alabama. Got it from GA because it was the best price in about a 400 mile radius. The place I got it from warrantied it though, so that's a plus... |
