![]() Join Date: Jul 2001
anyone know how to fix the rattle that occurs from 48-54 mph. something about the steering collumn? :confused:
james - sounds like you threw a weight and need to get your tires rebalanced. That is usually the case when you get a shake at a specific MPH.
Ming - get your front brake rotors resurfaced - they are probably warped. That causes a shake when braking. |
![]() Join Date: Aug 2001
hippo u pimp, solving all the worlds problems <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>.. i had the same shack problem, so thanks man, how much should i expect to spend rebalancing them?
Depends - many shops will do a re-balance for free if you bought/installed the tires there. If not, I don't really know - I'd guess $25? At any rate, it's not too pricey - just call around. You can also get a lifetime balance and rotation from shops for pretty cheap so you don't have to play rotate every few months.
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from konkman on 10:13 am on Dec. 14, 2001
What speed rating are your tires? I had the same problem with 205/55R16 T rated tires, when I put some H's on my car the vibrations stopped.</td></tr></table><span id='postcolor'> When you put the new tires on, they had to be remounted and balanced. That more likely stopped the vibration. |
When was the last time your checked your brakes. Nissan rotors are known to warp very easily. You made just need to get your rotors re-surfaced, to get rid of any imperfections. My steering wheels shakes like a mutha, and I'm pretty sure I need a brake job. So I"m gonna get some cross-drilled Brembo rotors front and back, and Axxis metal masters, or some other form of metal or carbon based pads. Hopefully that does the trick....we'll see.
Guest
Posts: n/a
Ming ming ....... u were about to get beat by s14grl lol thats funny tho <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=':p'>
