![]() I have a 89 s13 coupe sr20det, recently i would turn the key to start the car and nothing would happen, i couldn't figure out what it was until i ran a wire from a power source and touched it to the positive side of the starter, the car cranked right up. Im guessing it's my starter relay? Which relay is the starter relay? HELPP!!
![]() Join Date: Mar 2007
There is a little tab connection on the starter that the connector can come off of. It just slides right on to the tab, make sure that is connected.
#3 | |
i checked that first and it was on there, it is connected |
Yeah on the positive terminal of the battery if u have your sotck connector that came with the sr haRNESS there is a red block the has a black and green connector, i believe that the green connector is for the lower harness what i did was buy a tsunami battery terminal at auto zone and just cut the whole thing off, and whats nice about the tsunami connector is that i has individual slots for each cable give that a try i would think its that.
![]() Join Date: Nov 2004
The starter relay on a s13 is a blue relay between the battery and the fender.
Unplug the relay and jump the two thick black wires while doing nothing with the other plug. If it starts then you should get a new relay. Done.
i found a relay that had a black w/ white stripe and a black w/ yellow stripe going into it, but on the other side it of the relay the wires were cut and taped off???? what wire colors should i look for?
The blue relay for the starter is were the battery is there is a little hole that goes into the wheel well i know that sometimes the blue relay hides hanging in there thats were i would always find mine.
