Old 06-24-2008, 01:04 AM   #1
asobanai
asobanai's Avatar
asobanai is an unknown quantity at this point
Send a message via AIM to asobanai
s14 z32 brake upgrade assistance
s14 - i have managed to install the calipers and rotors sucessfully, however i noticed that the brake balance was much more in the front than the rear. i would brake and my rear end locks right up. i just put the bnr33 vlsd and it was a little much, i would imagine if i did the rears as well it will equalize the brake balance. Your opinion or knowledge? im thinking of getting some drilled and slotted rotors temporarily until i can get the rear brakes/calipers/spindles in the future. then again there is the brake booster and master cylinder from the z32 as a brake performance factor. aluminum 30mm they are, any words advice are appreciated.
asobanai is offline   Reply With Quote
Old 06-24-2008, 01:49 AM   #2
Modrified
Modrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of light
did you install your calipers in a way so the brake bleeder nipples are on the top of the caliper?
I CAN FLASH MODIFY YOUR XBOX 360.
Modrified is offline   Reply With Quote
Old 06-24-2008, 01:52 AM   #3
an_orange_s2k
an_orange_s2k's Avatar
an_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond repute
you should upgrade the brake master cylinder to the z32. brake booster is up to you
an_orange_s2k is offline   Reply With Quote
Old 06-24-2008, 02:10 AM   #4
GSXRJJordan
GSXRJJordan's Avatar
So you're running Z32 front brakes and stock rear brakes, with a Z32 M/C? Or are you running the stock S14 M/C?
Z32 fronts, stock rears = Z31 M/C for correct balance/feel. I run this setup.
Z32 fronts/rears = Z32 M/C.
Old 06-24-2008, 06:28 AM   #5
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
i run the same.... full z32 with z31 mc..... feels good....
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-24-2008, 02:06 PM   #6
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
yah im runnin the s14 auto/abs bmc, BM-44? i think, and it feels almost stock
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
