Old 06-26-2008, 04:39 PM   #1
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
SR rebuild... blowing assload of oil through VC?
So.. I'm getting a motor with a shitload of blowby through the VC breather..
I've rebuilt a KA before, but not a SR and I'm sure it's same principles, but what could that possibly be?
I'm not too familiar with SR, so I don't know what it can be..
off the top of my head:
rings?
valve seals?
owner said the oil was clean and free from metals and the block is in one peice..lol
lmk guys
My iTrader rating!
babowc is offline   Reply With Quote
Old 06-26-2008, 04:49 PM   #2
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
grand canyon ring gap?
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 06-26-2008, 04:51 PM   #3
babowc
babowc's Avatar
lol
i guess it's a simple fix, no?
My iTrader rating!
Old 06-26-2008, 04:55 PM   #4
statik
statik's Avatar
check your compression and do a leakdown test. If it's the rings, you're going to need to tear it down and get new rings and gap them properly.
Old 06-26-2008, 07:59 PM   #5
babowc
babowc's Avatar
thankkss!
I just went and picked it up..
ill see what it is
My iTrader rating!
Old 06-26-2008, 09:42 PM   #6
BustedS13
BustedS13's Avatar
i was blowing a ton of smoke after putting my KA back in. i forgot to drain the oil.
and then i put in a refill. so it had two gallons of oil in it.
....did you put 2 gallons of oil in your engine
Old 06-26-2008, 09:56 PM   #7
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
definatly sounds like some serious blow by.
bottom end rebuild asap.
total seal rings are garbage, dont use them.
sr20boostn20 is offline   Reply With Quote
Old 06-26-2008, 09:59 PM   #8
drifxtfx1
drifxtfx1's Avatar
drifxtfx1 has made poor choicesdrifxtfx1 has made poor choicesdrifxtfx1 has made poor choicesdrifxtfx1 has made poor choicesdrifxtfx1 has made poor choicesdrifxtfx1 has made poor choices
mine had a cracked piston, so look for that or rings and seals
drifxtfx1 is offline   Reply With Quote
Old 06-26-2008, 10:01 PM   #9
slider2828
slider2828's Avatar
Yes do leak down test, check your motor oil level, replace pcv valve, if KAT did you check whether if you have a restrictor on your turbo. Good luck..
Turn and Burn!
Old 06-26-2008, 11:21 PM   #10
babowc
babowc's Avatar
na
i just bought a motor.
ill check whats up.. more than likely a p-ring
ill start teardown after i get my ka-t finished
My iTrader rating!
