Old 07-01-2008, 06:16 PM   #1
AznDrftr.
AznDrftr.'s Avatar
AznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond repute
Send a message via AIM to AznDrftr. Send a message via MSN to AznDrftr. Send a message via Yahoo to AznDrftr.
quick question about the neo 2
I have it installed, just wanted to know whats the hotwire settings need to be on
right now, its on 1 in and 1 out after i reset it.
I heard numerous thigns about 2 in 6 out.
Im runnin hella rich right now and wastin gas at the same time. Just wantd to knwo what settings they need to be on,.
Stock sr set up, t25, aftermarket mani, z32 fuel filter, 255 walbro
lmk. thanks.
AznDrftr. is offline   Reply With Quote
Old 07-01-2008, 06:25 PM   #2
norbac
norbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant future
how are you gauging it, do you have a wideband?
norbac is offline   Reply With Quote
Old 07-01-2008, 09:00 PM   #3
240sxworkinprogress
240sxworkinprogress's Avatar
240sxworkinprogress is a well-known jackass
http://www.apexi-usa.com/pdfWiring/13.pdf Here you go!!
240sxworkinprogress is offline   Reply With Quote
Old 07-02-2008, 12:00 AM   #4
cotbu
cotbu's Avatar
6in / 6out stock setup
that list,
Has no effect on s-afc setup
If you have 370's? zero the high and lo. If you have a wideband? concentrate on tuning your lo setting for gas mileage. Setting the high will be the easiest.
I also used 3.5bar fuel pressure. on S-AFC Blue HTH
Old 07-02-2008, 03:37 AM   #5
AznDrftr.
AznDrftr.'s Avatar
alright good deal. thanks i'll put the hotwire 6in 6out.
Old 07-02-2008, 04:19 AM   #6
jinesz32
jinesz32's Avatar
jinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to behold
Send a message via AIM to jinesz32
mines 4in / 4 out.
jinesz32 is offline   Reply With Quote
Old 07-02-2008, 05:35 AM   #7
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
yeah, its 6/6 if you go z32 mafs it becomes 2/6...pm sent also
sidewaysil80 is offline   Reply With Quote
Old 07-02-2008, 08:40 AM   #8
upstate240sx
upstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really nice
i have a question about the neo, dont mean to steal the thread,
i have a 240sx with a sr20de+t, i have a stock maf right now, can i use a z32 maf without tuning the ecu? as long as i wire the maf in right?
upstate240sx is offline   Reply With Quote
Old 07-02-2008, 10:21 AM   #9
norbac
yes, i believe so, a friends car has basic sr + z32 maf, and nothing else, the afc would work he said when it comes to anything else, like injectors or turbo or anything drastic, go get tuned or blow up your engine but im sure getting it tuned would only do good
Old 07-02-2008, 12:30 PM   #10
upstate240sx
ok so i have a rwd sr20de im going to order all the parts to turbo it, now i need some kinda of fuel management setup, can i just buy a neo, and a z32 maf and wire the maf in and tune the neo and be all set?
Old 07-02-2008, 12:55 PM   #11
norbac
i dunno, is the turbo a stock sized one? get a wideband to monitor just to be safe
Old 07-02-2008, 01:30 PM   #12
upstate240sx
yea but my question is, will the maf work, i dont need to program the ecu right, i planned on getting a wideband any how
Old 07-02-2008, 02:51 PM   #13
norbac
i dont see why not, sr20de, z32 maf, hopefully you can figure out the wires from the neo to the ecu, theres not that many wires to splice, hope someone can answer it definitively, because i dont really know... one way to bypass the maf is if you can find that apex power fc djetro or whatever its called, more expensive but from what i heard, its alot better than the afc, the one that doesnt need maf and uses a map instead
Old 07-02-2008, 02:57 PM   #14
steve shadows
steve shadows's Avatar
S-AFC is a piece of shit/trash . The faster people figure this out the sooner people will stop blowing pistons, overheating exhaust manifolds (cracking) and cluster fucking their timing map cell placement on their ecus. How do i know this? I used to own one of those herpes boxes.
Like Me on FaceBook !
Old 07-02-2008, 03:05 PM   #15
upstate240sx
why is it shit...
Old 07-02-2008, 05:40 PM   #16
S14DB
AFC #1
S14DB's Avatar
Originally Posted by upstate240sx View Post
why is it shit...
Cause it fakes out the ECU to increase/decrease fuel. Unfortunately most ecus adjust ignition timing too. At the least this makes the timing retarded and raises the EGTs sky high. Melting/cracking exhaust components. Wost case it advances to the point of detonation.
Old 07-02-2008, 04:13 PM   #17
norbac
all i know is the afc only tunes the fuel maps to a certain degree, you need the whole shabangabang with standalones, which costs moolah, but everything is tunable
Old 07-02-2008, 05:00 PM   #18
upstate240sx
yea if ur looking for like 600 hp, you can get along on bigger injectors and run piggyback fuel quite a bit, standalone is a god damn nightmare compared to the neo
Old 07-02-2008, 05:02 PM   #19
upstate240sx
howd you guys figure out your setting like 6/6, or for a z32 2/6 , would does the in and out mean?
Old 07-02-2008, 05:06 PM   #20
upstate240sx
also i was wondering this, how does the neo kno how much fuel to dump if it doesnt know my injector size, whats to stop it from spraying the same pulse duration and width with a 370cc injector as it does with a 1000cc injector? is this where those 16 points of tuning at every 500rpms comes into play,?
Old 07-02-2008, 05:26 PM   #21
norbac
power fc is a great compromise, it is an ecu with maps for fuel and timing, nothing as fancy as the other standalones with much more tunability. i believe you can find those info in the actual manuals? the afc just goes by what is standard, so if you have 370, it assumes you have 370, so if you double it, you change the map by half, or something to that affect... i could be wrong, i was curious too, but i was researching this too... im probably wrong, so i personally would just go get it tuned if i were changing injectors size or any major upgrades...
Old 07-02-2008, 07:25 PM   #22
upstate240sx
norbac:you said "you change the map by half? where do you do that at, or what do you specify, at the in/out screen?
Old 07-02-2008, 07:40 PM   #23
S14DB
AFC #1
S14DB's Avatar
You can only trim upto 50%. So, the biggest injectors you could run is 555cc on a SR that uses 370cc stock.
Old 07-02-2008, 09:21 PM   #24
upstate240sx
how is there a limit to the injectors you can run. . . can someone explain in horrifically extreme detail how the neo works 2 me,
Old 07-03-2008, 11:54 AM   #25
norbac
that is the limit, really cant explain it any other way, you can put increments throughout the rpm range, but it only goes up to 50% up or down, but thats it, so if stock is 370, then 50% on top of that is 555, just like he said, thats why afc is good up to a certain amount, after that, go get something better. better piggy back is emanage. better than that would be standalone, power fc is good for basic standalone. better than that costs a lot but a lot more features, more than i know. obviously i dont know that much, its just from my research and what friends tell me, haha
