Old 07-09-2008, 07:12 PM   #1
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
HKS wastegate actuator install question
so i put the hks wastegate actuator on my s15 t28 and it seems like it as it quite an angle. should i be concerned?
here is a pic
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 07-10-2008, 12:37 AM   #2
cotbu
cotbu's Avatar
No, don't be concerned! It's OK!
As long as the eye hole, is flat against the flapper arm your golden.
OK, got a tip/trick for you. Wrapping the actuator arm with grip tape makes for quick and easy adjustment.
Old 07-10-2008, 12:39 AM   #3
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
that is quite an angle. are you sure it's not a t25 actuator if it'll even fit? just throwing out a suggestion.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 07-10-2008, 12:58 AM   #4
drift925
drift925's Avatar
drift925 is close to perfectiondrift925 is close to perfectiondrift925 is close to perfectiondrift925 is close to perfectiondrift925 is close to perfectiondrift925 is close to perfectiondrift925 is close to perfectiondrift925 is close to perfectiondrift925 is close to perfectiondrift925 is close to perfectiondrift925 is close to perfection
Maybe you need a different bracket?? I know brackets are turbo specific.....
drift925 is offline   Reply With Quote
Old 07-10-2008, 01:01 AM   #5
SoguRacing
SoguRacing's Avatar
perhaps he's right. i have the t28 HKS actuator on my gt2871 and it sits flat..meaning it's straight across.
Old 07-10-2008, 07:31 AM   #6
devonkyle77
i know its the t28 kit for s14/15
i bought it new, and prior to this, i purchased one off of a forum member that was supposedly for t28, but the bolts were spaced different. meaning it was for t25
Old 07-10-2008, 07:33 AM   #7
adictd2b00st
adictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to behold
Send a message via AIM to adictd2b00st
hmm.... mine sits flat, but like they said it should still be fine
adictd2b00st is offline   Reply With Quote
Old 07-10-2008, 11:53 AM   #8
!Zar!
!Zar!'s Avatar
Yeah, that angle is a little much. It will still work, but something like that would annoy me just to know it's like that.
I would either bend/make another bracket, or put a spacer on one side to try and angle it.
Old 07-11-2008, 12:55 AM   #9
2JZGTE
2JZGTE's Avatar
2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute
Send a message via AIM to 2JZGTE Send a message via MSN to 2JZGTE
Ya I'm sure it works OK but really does look quite angled. I have the S13 and S14 ones installed, if you want post up the PN# for yours and I'll check mine to match up. Just doesn't make sense, they've always lined up for me and others so wtf is up.
Could have always gotten the wrong bracket too (they ARE s13/s14 specific) but it looks like the S14 one from the pic.
Billy
R35 GT-R, R32 GT-R, Supra, S13, S14, FD3S
2JZGTE is offline   Reply With Quote
Old 07-11-2008, 10:13 PM   #10
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
Are your housings clocked?
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 07-11-2008, 10:26 PM   #11
devonkyle77
not sure, as i did not purchase the turbo new. i have no idea how to clock it if thats the case.
