Old 07-19-2008, 04:13 AM   #1
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
[SR] Boosting until redline
Asking everyone with a sr20det with stock t25 turbo boosting over stock how much boost can it hold to until redline?
Currently i am boostin about 12psi on a mbc. It will not hold the 12psi all the way to redline it will drop all the way down to 7psi i think after 5,500rpm. I tried cranking boost to 14psi and it is still dropping. I know the stock t25 does start losing boost to redline but how much?
My friends car holds 12psi all the way to redline.
Boost leak? exhaust leak?
Car drives fine and idles fine. Just doesnt pull hard up top from the decreasing boost. Full exhaust and fmic.
Thanks.
reccakun08 is offline   Reply With Quote
Old 07-19-2008, 07:12 AM   #2
Def
Mine held about 11.5 psi to redline, and it was in great condition when I took it off. Could have probably held a bit more with an EBC, as I just had a cheap MBC at the time.
Old 07-19-2008, 07:38 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Get an AVC-R, nuff said...
CLICK HERE!!!
Old 07-19-2008, 07:54 AM   #4
tha240star
tha240star is making a name for him/her selftha240star is making a name for him/her self
i have a turbo xs mbc and it holds 13 to redline, its spike a lil at first to like 14-15 but thats about it
tha240star is offline   Reply With Quote
Old 07-19-2008, 08:27 AM   #5
SoSideways
SoSideways's Avatar
I have a Turbo XS dual stage MBC, and it can only hold about 8psi to redline. At the time of the dyno graph, I had it set at 14psi.
Old 07-19-2008, 09:28 AM   #6
s15specR
s15specR's Avatar
Trader Rating: (18)
s15specR is making a name for him/her selfs15specR is making a name for him/her self
Feedback Score: 18 reviews
I got a new in box AVC-R for sale, hit me up if you need it, will let it go for the low
s15specR is offline   Reply With Quote
Old 07-19-2008, 10:17 AM   #7
reccakun08
reccakun08's Avatar
i have Turbo XS dual stage MBC. You think thats the reason im not able to hold boost? Sosideways my graph is similar to yours. Gotta find it.
s15specR pm a 'low' price shipped.
Thanks.
Old 07-19-2008, 10:59 AM   #8
garbury
garbury is making a name for him/her selfgarbury is making a name for him/her self
I made my own mbc and it hit 15 psi and dropped gradually to 12 by redline. http://www.geocities.com/chmwatson/FAQs/mbc.html I threw on my ebc with the stock t25 and it would still drop down by redline. The t25 turbo has problems holding boost levels that high, unless an avcr is really that legit.
Honestly, besides the ability to change boost on the fly, I'd prefer the $12 hardware store boost controller over my greddy profec type-s.
garbury is offline   Reply With Quote
Old 07-19-2008, 11:28 AM   #9
!Zar!
!Zar!'s Avatar
The stock wastegate on a t25 freaks out once you start trying to raise the boost.
Also, I hope you aren't trying to boost your car that high with stock sr and no management.
haha.
Old 07-19-2008, 04:01 PM   #10
Def
haha.
14-15 psi on a stock T25 with a stock ECU/injectors/MAF is just fine. The AFR curve is as jacked as it is on stock boost(lean in the midrange), but it's fine for the most part, especially street driving.
I recommend a FMIC to keep IATs down, as it doesn't take long for the SMIC to give up the ghost when trying to cool a little hairdryer like a cranked up T25.
Old 07-19-2008, 01:48 PM   #11
reccakun08
reccakun08's Avatar
yeah i thought about trying the hks actuator to see if does indeed help and guess prove the mbc isnt reliable.
Old 07-21-2008, 11:43 PM   #12
reccakun08
reccakun08's Avatar
Would an exhaust leak or a boost leak be a probable cause?
Old 07-22-2008, 01:51 AM   #13
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
could be
its possible one of your lines are backing off during boost.
i was having the same problem, so i reclamped and ziptied all my vaccum lines that i had been around (recent install of avc-r)
ILoveJDM is offline   Reply With Quote
Old 07-22-2008, 08:28 AM   #14
SoSideways
SoSideways's Avatar
If you're worried about a leak, get yourself a pressure tester, hook it up to where your MAF would be, and pressurize the system to like 20psi.
You will find your leaks much better with that method, if you have any leaks at all.
Old 07-23-2008, 04:54 PM   #15
codyille
codyille's Avatar
codyille is an unknown quantity at this point
I've seen this problem with homemade boost controllers. Try a higher quality controller. Or different vac line?
codyille is offline   Reply With Quote
