Old 12-27-2002, 03:26 PM   #1
ghosts14
ghosts14 is an unknown quantity at this point
I'm about to go nuts
It has been about 6-8 months since I have installed the Hotshot Headers into my 96 se. When I first drove the car after they where installed the steering knuckle hit on the side of the one pipe. I figured with enough rubbing it would dent it enough to stop the rubbing. Well I guess I was wrong cause it is still rubbing.
It olny rubs when I make hard right hand turns and a fast speed, not at all with left hand turns. My logic is that the body of the car is moving to right in a right handed turn and the engine is mostly staying put or in a straight line. So in a right handed turn the steering knuckle will be pushed closer to the engine causing a rub and a hard time tuning the steering wheel.
Now, when I did the complete exhaust system, I did not but the little hanger bracket back on that is located close to the transmission. Is that what is causing the problem? I personally doubt it. What can I do to make this stop rubbing, as it is driving me to seriously think about putting the stock exhaust maniford back on.
So far what I think is maybe replacing the engine mounts to some poly or nismo mounts, which I have no ideal how hard that will be. Or something that will limit the body roll, like a strut bar. Tell me what you all think.
Sorry it is so long.
GhostS14
-'96 240sx se
-Injen Intake
-OBX SS
-HotShot Headers; Ran. Tech Cat; 5Zigen Border3
-KYB AGX's; H&R Springs
-Whiteline front and rear swaybars
ghosts14 is offline   Reply With Quote
Old 12-27-2002, 10:29 PM   #2
SaintlyCharBoy
SaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her self
Send a message via ICQ to SaintlyCharBoy Send a message via AIM to SaintlyCharBoy Send a message via Yahoo to SaintlyCharBoy
all i can say is that with a virtually identical setup i do not experience this rubbing of which you speak
i also omitted the tranny hanger as it made the exhaust hang at funky angles to the header, and the header flange was welded
my vote is to yell at HS
-sean
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage
95 base - retired
SaintlyCharBoy is offline   Reply With Quote
