Old 08-03-2008, 07:59 PM   #1
Shift_Dr1ft
Shift_Dr1ft will become famous soon enoughShift_Dr1ft will become famous soon enoughShift_Dr1ft will become famous soon enoughShift_Dr1ft will become famous soon enough
Problem getting shifter out
Hi all,
I am in the process of changing my shifter bushing. The problem is that I cannot take out the two inner bolts that's hard to be reach. I tried dropping my tranny but one of my bolts are stripped so I do not want to brake the bolt. I was wondering if I can take out the (snap spring)? Or is there any other way? Thanks
Shift_Dr1ft is offline   Reply With Quote
Old 08-03-2008, 08:05 PM   #2
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
Why pulled out the whole plate? Just pull out the shifter.. all you need is 2 Flat head screw drivers.. It's only two rings holding it in
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 08-03-2008, 08:09 PM   #3
iluvpandas4
iluvpandas4's Avatar
iluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfection
Send a message via AIM to iluvpandas4
Do what the man says, because even after taking out those 2 screws you still need to deal with pulling off the shift plate (it's sealed to the tranny or at least mine was..). Pulling out the rings is way easier.
'92 240sx Coupe
iluvpandas4 is offline   Reply With Quote
Old 08-03-2008, 08:12 PM   #4
Shift_Dr1ft
Alright thanks guy! So all I need to 2 flat head screw drivers to take out the rings? Cause I asked a friend and he told me a needed a special tool to get the rings out...
Old 08-03-2008, 08:16 PM   #5
iluvpandas4
I used 2 flatheads, at first it looks difficult but once you really take a good look you'll figure it out easy. I wish I had pictures to show you.
'92 240sx Coupe
Old 08-03-2008, 08:24 PM   #6
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
u could use a special tool like ur friend says but u can also use pliers or a flat head
Old 08-03-2008, 08:27 PM   #7
Rittmeister
Rittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really nice
You can get a snap-ring pliers that'll work, pretty cheaply, and it makes the job go very easily. You only have to remove one ring, not both - the one with small circles on the ends.
E36 M3 - new project
1990 240SR - screamed down the road
Rittmeister is offline   Reply With Quote
Old 08-03-2008, 08:30 PM   #8
Shift_Dr1ft
Alright guys I got this. Thanks a whole lot.
