clutch
My car wont go into gears, i have to turn the car off to put it in to first. and when its in first with clutch IN, the cars slowly still wants to move forward.
Does this mean the clutch is gone? Slave cylender is gone? i have plenty of fluid. What do ya guys/gals think? thanks for the inputs. |
Probably your slave cylinder. Go under the car and have someone pump the clutch and see if the pin moves. Could also be your master cylinder. Does your pedal have pressure? Most likey slave tho. good luck.
Drunk posting FTW! ![]() |
Could be worn out slave or master cylinder, air in the lines, bent clutch fork, or misadjusted clutch pedal.
Bent clutch fork seems most likely. If you haven't removed your clutch dampener tube it could be causing you problems. First thing I'd do is flush/bleed the hydraulics. |
thanks for the replys, it all started after i threw a big miss shift at big willow this weeks end. im worried its the clutch, no money to replace one right now : ( and yes the clutch has pressure.
![]() Join Date: Dec 2006
go under the car and have someone pump the clutch to bleed it out and get all the air out of the system. also check for rips in that shitty rubber hose that Nissan made that goes to the slave cylinder. after you completed the bleeding check the pedal feel and see if the pin on the slave moves the tranny fork.if it does and all looks good their check the hardline for any kinks. hardline goes from the CMC to the box T fitting then to the rubber hose to the slave. if you bleed the clutch it should be fine. let us know what happens when u bleed the slave and when doing so dont let the fluid go below half GL.
#7 | |
![]() Join Date: Sep 2005
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
Go from there, my 2cents.
Do you suffer from vaginal dryness... |
![]() Join Date: Dec 2002
Broken fork pivot, bent fork, broken front cover, or dead cylinder.
first of all i want to thank you all for chiming in and putting in your two cent. i just got done bleeding the clutch twice, and so far so good. so thank you to all of your and wish me luck !
