Old 09-18-2008, 11:03 PM   #1
nismo 240sx
nismo 240sx's Avatar
nismo 240sx has a little shameless behavior in the past
KA 240 experts
hey my check engine light is on and it says its a knock sensor and it also says iacv-aac...
is it bad if i drive it around like that. the car runs smooth but iam afraid it will die on me.
nismo 240sx is offline   Reply With Quote
Old 09-18-2008, 11:13 PM   #2
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
The knock sensor (code 34) code is 90% of the time because of a short in your wiring to the knock sensor. Other times, the sensor itself has melted or been destroyed. It will not harm your engine driving like that. However, because that code 34 is stored on your ECU, you will notice your engine produces a lot less power than normal (timing is retarded to prevent knock). To fix the issue you need to find the short in the wiring and splice/solder to repair it (or replace the sensor itself if it's bad). If you search around for "code 34" you will find many posts on the topic, where to look for the short, how to replace the knock sensor, etc. It's a common issue on the KA24DE.
IACV I don't know the solution, you may have a short or the unit itself might be bad/gummed up/etc.
MELLO*SOS is offline   Reply With Quote
Old 09-18-2008, 11:20 PM   #3
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
I don't think the ecu is smart enough to detect a mechanical failure in the iacv (gummed up, etc...). It almost certainly has an electrical problem. Not onlyu that, but I have actually taken an iacv apart and I see no reasonable way that the iacv could get clogged. To start make sure the connection for the sub-harness that goes under the intake mani is clean and stick a pick or small screwdriver in there and crimp down the female pins a bit more. Also make sure the iacv connector itself is actually plugged in, clean and tight.
Old 09-18-2008, 11:38 PM   #4
Drifterxxl180
Drifterxxl180's Avatar
Drifterxxl180 is on a distinguished road
I'd try what he said check resistance with a meter and check for continuity to ground
Drifterxxl180 is offline   Reply With Quote
Old 09-19-2008, 12:32 AM   #5
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
google 240sx iacv tutorial. there are a number of electrical things that could be wrong with iacv.
surreybc is offline   Reply With Quote
Old 09-19-2008, 10:24 AM   #6
nismo 240sx
thanks you guys ill do it tommorow since it is my day off!
