Z32 turbo pistons in SR20DET
hey guys i was looking around and found that some FWD SR guys are putting Z32 300zx turbo pistons in there DE motors as a cheap alternative to expensive forged overbore low compression pistons. The info i have on them so far is that they are 87mm and 8.5:1 compression ratio and fit the oem rods. I have yet to hear of anyone using these in their rwd SR20DET, I may try it as i have to bore out my block and need to save money somewhere. Plus I wont be going over 350hp so I think these will be a good option. If anyone has any info on this or has done it before, please post. I am really interested in this option rather than spending $500 on forged pistons.
#2 | |
![]() Join Date: May 2006
You don't need aftermarket pistons for 350hp... just a good metal head gasket, a bigger turbo, and the associated fuel mods. BTW, stock SR pistons arent bad. I would imagine the only advantage to the VG pistons would be 1mm overbore, but I'm not all that comfortable boring the already-thin-walled SR anyhow.
![]() Join Date: Sep 2006
Or You Can Get Some 2JZ-GTE Pistons...they Are 86mm And 86.5 And 87....If they Fit On The SR Rods ( I don't Think So)
And On Supra's They Made Up To 1017Whp On STOCK Engine Then the rod bolt's gave up.... ![]() Ali
'95 S14 Se With HKS's - BREMBO's - ES/SPL. |
Around there, yes.... but read his earlier post:
Interesting. So you've got scoring and must overbore? I'd say it's a decent plan... I'm guessing a set of 4 Z32 pistons is less than $100?
new ones won't be any different than used ones if there is hardly any wear on the used ones and i would put new rings on them. its not like pistons wear out or get weaker over time...
#13 | |
![]() Join Date: Apr 2004
Whether it will fail as a result, I doubt it. But to save $100 and risk the PITA of replacing pistons or scrapping a block - why would you even think about tossing in used OEM pistons? |
#14 |
Alexander500: I dont see why its such a bad idea to reuse used pistons? plenty of rebuilds are done reusing original oem pistons. I will be using new rings. The pistons dont necessarily wear out...The only thing to worry about is metal fatigue.
#15 |
![]() Join Date: May 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
i think what everyone is getting at is why would you not replace something critical to your motor like pistons, especially when they are so cheap to replace???? to me its a no brainer whether or not to replace the pistons in this situation.
#17 |
i have heard that Sr Rods are actually a strong point to the motor... Check this out... 4G63 Turbo Rebuild with VG30DETT Pistons 87mm - Zerotohundred.com - The Automotive Lifestyle Network I guess they rebuilt a 4G63 with the VG30DETT pistons and are pushing 600hp.. oh and thats with used VG turbo pistons and stock rods.
#18 |
Alright so i sourced a set of low mileage used VG30DETT pistons, Dirt cheap and in great condition. I also found a guy who has a SR torque plate that is willing to let me use it to get my block overbored the 1mm needed. Machining cost are going to be the most expensive thing but i think after everthing is said and done I will have saved hundreds of dollars from going aftermarket pistons and only have spent a little bit more than if i would've had a good block to have started out with and was just doing a OEM rebuild. So basically I will have an 1mm overbore OEM rebuild when everything is said and done.
#19 |
![]() Join Date: Jan 2007
Just make sure the pin height , and amount of CC in the dish...
you need around -12cc of dish on a stock SR or there abouts... VG pistons in a SR sounds good if its that cheap thou.. go for it
#20 |
Its been done before i know that alot of fwd na SR guys use the na VG pistons to bump compression up. The VG turbo pistons are even more stout then the SR turbo pistons too. I will take pictures of everything as the process goes along.
#21 |
![]() Join Date: Mar 2003
HKS Driver (NOB) Nobuteru Taniguchi uses Z32 pistons in his S14 SR20.
I have been thinking of this and keeping it on the DL... This is one of those rare things you hear little about. -Drew |
#22 |
I didn't know that! Wow. Does that mean he's running HKS forged Z32 pistons, or OEM? Moarrr infoooooz pllzzzzzz.
#23 |
He is using stock Z32 pistons... not the HKS.
He also suggest that the Z32 pistons creates a 2.1 option... if you look at the pistons (SR vs Z32) the Z has a shorter profile. This is a Z32 Piston from Wiseco (88mm) This is a SR20DET Piston from Tomei (87mm) ![]() -Drew |
#27 |
I dont see it as such a big deal as most people are making it out to be to use new pistons rather than good condition used ones. I think that if i agreed that it was such an important thing to use new ones then i would also want to get new rods, which see about the same abuse as pistons do in my mind. I have yet to get pistons so my mind isn't completely made up in whether or not i am going to get new pistons or just use used ones.
#28 |
![]() Join Date: Oct 2004
I have actually heard this in other cars. Like 2zz motors used like honda pistons or something like that.... I think the esprit's mrs does that....
#29 |
yeah i have heard of D series honda motors using suzuki grand vitara pistons which lower compression and are stronger, they use them when the turbo the D series motors and have been able to get like 400hp with no problems. Thats what got me looking into alternative pistons for the SR motor, especially since i have to overbore my block and didnt want to spend and arm an a leg on forged slugs since im not planning on making huge power.
