![]() Join Date: Jun 2005
+50 mm rear fender folks - whats your wheel setup?
just curious what everyone runs in the rear on the +50s for tire and wheel size, how aggressive, rubbing etc
floridaracing.org SR20DET 510/350whp - S13/702HP/V8 - 07 350z/343 WHP |
It really depends on what type of over fender you get. You will find that your claimed +50mm wide fender might actually can be anywhere from +30 to +70 depending on the design of the fender, how you mount it, and how much of the inner lip you leave in.
Mine are the Origin type 2 50mm over fenders. But if i just put them on as they came, no way in hell i would be able to fit any low offset wheel due to the terrible design of the edge of the lip. (hence why i cut it out). If you have an origin type 1 or charge speed 50mm wide fender i would suggest: x10 wheel with -25 offset x11 wheel with -15 offset x12 wheel with -5 offset This will allow you to fine tune your tire clearance using small (5mm) spacers, tire width, camber etc.. to get it nice and close.
R34 NEO POWER |
#7 | |
![]() Join Date: Jul 2007
im running 50mm/18x10.5+15 with a 265/35/18 its right there close to the fender. if u run such a aggressive offset u just said on a 50mm u gonna have to stretch the shit out of that tire. my new set(not here yet) its 18x10-6 rears . im gonna have to remove the inner section of the fender . dont like to stretchy that much . specially making 440 suggest offset for 50mm anything from +15 down to -5 or 10 the most for a 10 wide wheel . if u like to stretch go lower
![]() TRUE thing: True ////OFFSET\\\\ is acheived without spacers Running on E85 570whp Precision 5862....laggy as fuck. hate it |
#9 | |
![]() Join Date: Mar 2002
![]() Feedback Score: 9 reviews
Don't listen to these guys.
17x7 +35 is where it's at.
how is it that people with 50 rears run 18x10.5 +15 with 265 thats tight fit and some that have 18x12 +5 with 275 that are tight fit
ive avged out what i have seen and with a +40mm front fender with a 18x10 0 with a 245and 18x11 0 rear +50 with 255-265 works can anyone confirm this fitment?
#12 | |
![]() Join Date: Oct 2006
My fronts were hella hard to get to turn lock to lock and require alot of hammering They also rub the fender alittle bit because im pretty low. The rears were cake though. |
#13 | |
#14 |
![]() Join Date: Sep 2003
if its anything. im running an 18x9 +15 rear. sticks out about 15mm on a stock fender. have 50 chargespeeds. a 30mm spacer will make it pretty flush. 235/35/18
#15 |
Like i said this all really depends on how you mount the fenders. Anybody here who is anal about wheel fitment would remove the inner lip on any wide fenders. Why? because that's another 1-4cm (mine was about 4cm ) that you simply cant use. The tire has to sit behind that lip or else it will rub when you lower it. I cant imagine why one would not cut he lip down for more clearance.
R34 NEO POWER |
#16 | |
![]() Join Date: Apr 2004
#17 |
How in the hell is 18x10.5 +15 a tight fit when people are rocking this size wheel on stock S14 fenders. lol I have 18x10 +20 right now and have no problems at all. Just rolled fenders, NOT pulled.
#18 |
I suppose we should also specify which platform we are talking about here too. S14 fitment is different than S13 fitment. Especially since the over fender designs for each chassis is completely different.
The hands down best way to find out what wheel size you need is just measure. throw some set of wheels on that you know its dimensions. Then measure and calculate to find what offset you need for a given width. Thats what i did with mine, and it is FLUSH.
R34 NEO POWER |
#21 |
so this is where im confused how these sizes vary so much. I talked to a guy that had
18x10 +10 225/40 with 20mm front fenders that fit with no issues on 3.5 degrees of camber. if you add 20 mm to that wheel size for a 40mm fender, you should be able to fit a 18x10 -10 offset with no fitting issues, but yet you said it is really tight on a -3 ? have you measured the knock offs? are they true 40mm?
#22 | |
Man w/ CTSV & a Car Seat
Its also a good idea to make sure you're alignment is good in the rear, specially make sure the camber is even on both sides. Last thing you wanna have is have a -5 and a -2 uneven camber when you try to put on the fenders. Shits gonna throw off your install. |
#23 | |
![]() Join Date: May 2006
Use threads like this to get an idea, sure, but eventually you're gonna have to: 1) get your camber set 2) cut your metal fenders/reweld if you care about the car 3) mount the widebody fenders and "pinch" the sides for more clearance, "press flat" for less. Would recommend spacers rather than pressing flat ![]() I've actually never done a "real"/brand name rear overfender install, just used "generic" overfenders, which look like ass until you smooth them in... but they certainly teach you how to make them fit your desired wheels. I got 18x12 -10ish Veilside Andrews to fit under "50mm" overfenders when I used to work at a shop.
#25 |
so basically 18x10.5-12 = 18x11 0 in relation to the fender clearance, how close it it?
#26 | |
My setup as I PMd you is 18x11 -5 255/35, switching to 265s soon I also have 18x10.5 -10.
PROCEED Grip Gambler |
#27 | |
i think 18x10 0 with 245/35 front and 18x11 0 275/35 rear is the way im going to go. if i need to put a small spacer for flushness thats better then having too big of a wheel made. thanks all.
#28 |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() Feedback Score: 3 reviews
As close as you want to install the fender... You should be able to make those work well though
Just talking about cars, one ![]() Horsepower sells cars torque wins races -Shelby |
#30 |
![]() Join Date: Oct 2007
Currently I'm trying to stuff 18x11 -16 works behind a 30mm. 245/40/18 tires and about -4/-4.5* camber.
I'll let you know how that works out, lol.
Blow me, bitches. ![]() |
