Old 01-19-2003, 08:01 PM   #1
S13Dreamer
S13Dreamer's Avatar
S13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really nice
Send a message via AIM to S13Dreamer
Unhappy Stalling while driving....
as the title says...when i'm driving my 93 240...and i want to down shift...sometimes the RPM drops so low...the car stalls...as car is rolling!!....my foot is on the clutch...so it's technically in neutral...it only happens every so often...but it'd kind of scary...and at times the car idles between 900-500...i'm thinking 500 is pretty low....could someone tell me what's goin on?? could i just adjust the idle to a higher setting?? thanks...
http://img.photobucket.com/albums/v118/s13dreamer/tobysig.jpg
S13Dreamer is offline   Reply With Quote
Old 01-19-2003, 08:10 PM   #2
Titan
Titan is an unknown quantity at this point
Do you mean that your idle fluxuates between 500-900? If so, it could be a vacuum leak. Check your AIV system over.
Otherwise, you can adjust the idle using the screw on the ECU.
Sleep Doesn't Drink Beer
Titan is offline   Reply With Quote
Old 01-19-2003, 08:57 PM   #3
96SEChick
96SEChick's Avatar
96SEChick is an unknown quantity at this point
Does it idle low when you're sitting at a light in Neutral, or when you start the car and let it warm up? If both those instances have normal idle, I would agree w/ Titan on the vaccuum leak, or even possibly a hose somewhat "collapsing" when your RPMs fluctuate when down-shifting.
Lauren
'91 300ZX TT Ultra Red 5-speed - JWT POPCharger, JUN flywheel, ACT clutch, Energy Suspension Bushings, Tokico Blues - dyno'ed 295hp/306tq
'94 300ZX TT Black Emerald Pearl 5-speed - JWT POPCharger, JWT ECU w/ Stillen chip, Stillen exhaust, Tokico Blues, Eibach ProKits, 18" Enkei RP-01 wheels - dyno'ed 333hp/385tq
'00 WS6 Trans Am Bright Red 6-speedFOR SALE - only 29k miles, stock, fully loaded, only $23,999 (NADA $26300)
Green Country Motorsports
Northeastern Oklahoma SCCA
96SEChick is offline   Reply With Quote
Old 01-20-2003, 08:12 PM   #4
S13Dreamer
S13Dreamer's Avatar
it doesn't idle low at a light when i'm on neutral...only when i'm slowing down and put the car in neutral it does...it's probably a vacuum leak??
Old 01-20-2003, 08:41 PM   #5
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
that very well is a clogged or bad aiv valve. I know my car did it and we cleaned out my throttle boddy with carb cleaner and it went away for a little while but then came back. Now its worse than ever. yes when you are in neutral at idle sometimes it will just drop to the point it stalls. We are probably gonna go after my aiv tomorrow . Which I am not looking forward to because those things are a total pita to get to remove and clean or replace.
New Video
Buy my mounts!
Old 01-20-2003, 10:26 PM   #6
AKADriver
AKADriver's Avatar
hell, it was easy to fix in my '90.
I got all the hoses going to it out of the way, unscrewed the clamp, pried off the top cover, and blasted the insides with carb cleaner. I let it soak in a while, buttoned everything back up, and it's run like a champ ever since. Maybe 15 minutes total.
Old 01-20-2003, 11:15 PM   #7
JerkFaceJason
JerkFaceJason is an unknown quantity at this point
AKA driver where is the AIV located? is it that plastic box that is connected to the air intake with a little hose?
JerkFaceJason is offline   Reply With Quote
Old 01-21-2003, 12:46 AM   #8
AKADriver
AKADriver's Avatar
The box isn't the valve itself. The AIV is a weird looking metal thing bolted to a bracket that's bolted to the driver's side strut tower. That black box is in the tubing that goes to the AIV from the airbox.
Old 01-21-2003, 10:02 PM   #9
S13Dreamer
S13Dreamer's Avatar
so...the AIV is connected to the airbox....now...i see three that connect to the airbox...which one is it?? is it the one that is close to filter?? or one of the two that are connected by the throttle body??...
Old 01-22-2003, 01:05 AM   #10
drift freaq
ya my bad. I was thinking about the S14 its a total pita on the S14 on my S13 its just like yours which is easy to get to. I am doing mine tomorrow.
New Video
Buy my mounts!
