![]() Join Date: Jan 2003
heat shield removal help please!
i got an s13 and my heat shield is rattling bad. i tried to take it off but it wont squeeze between the exhaust manifold and the powersteering or brake crap, anyone know how to take it off without taking off too much stuff?
1991 240sx se red w/ big #$* dent in it!! 5 speed injen cai apexi n1 dual unorthadox pulley set oh yeah and a blown motor |
Dremel.
Those heat shields are so rusted anyways a dremel would probably be your only option. |
![]() Join Date: Dec 2002
![]() Dremel will work but be careful not to use the bigger cutting wheels. You could push too hard and hit the mainfold, that could become a pain in the AS*!
Use the smallest wheel you can find, new wheels will cut through it like butta!! Good luck!
Don't mess with my monkey...he's loaded. |
i got no clue what a dremel is. is it a circular hand saw? i couldnt get one of those. would a hack saw do? lol
Google is your friend.
http://www.dremel.com/html/home_fr.html You can find them at almost ANY hardware store including KMart, Walmart, etc. -Charlie |
so a hack saw wont work?
![]() I would have to say that a hack saw wouldn't work. Well it probably would if you want to do it the ghetto-try to save a buck-mickey mouse-make it harder than it has to be-way.
If you go to Walmart or Kmart you can find a good quality dremel for about thirty bucks. Trust me it's not a one use item. I bought a Black & Decker for 35.00 and I swear that thing has helped me with repairing scratches on my rims, clipping extremely long bolt stems, cutting out chunks of metal so my cold air extension would fit in the small hole without scraping everytime I start up the car. Trimming down the stems on my new motor mounts so that they go on easier. Yeah it's kinda like a hand held circular saw but with attachments, no blade. If you do decide to get one, get one with the variable speed dial, and ask an employee for help finding a good one when you get to the store. Ask them for any tips they may have with using one. Try Home Depot or Lowe's if you can they're really helpful. Good Luck, and don't cut off your fingers!!
thanks for the help. heheh dont got thirty to spare right now. just put money into a jun flywheel.
![]() Join Date: Jan 2002
![]() ![]() ![]() Feedback Score: 1 reviews
which heat shield is rattling?
the one on the cat or the on on the manifold its self? if it's the one on the maiifold just take out the o2 sensor and bend the **** out of it until it comes loose the cat manifold - well, i threw it away with my cat when i went to a 2.5 inch hi-flow
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage 95 base - retired |
yeah i heard you could bend the hell out of it to get it out. but theres some accessory on the other side of it near the drivers side and i dont want to break something there. i was just thinkiing of takin of theh o2 sensor and hacking it from that hole to the edge.
get some sheer metal cutters, about 4.99, and cut the bitch off, then remove the three 10mm bolts
fast cars are dangerous, save lives drive HONDA'S |
yes got it off!!!!! is the exhaust manifold heat shield vital? rattles gone!!!!!! thanks for the help dudes
is the heat shield over the exhaust manifold necessary?
#14 |
not necessarily, i believe its put there by the factory to protect you from the hot pipes
