Old 10-04-2008, 08:46 PM   #1
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
s13 S13 RUCA installation question
i installed my PBM ruca's in the process i found this strange bolt that connacts the ruca to the subframe i was wondering if it could possible be replaced by a new normal grade 8 bolt?
car does not have HICAS. the nissan part number for the bolt in question Part number: 55226-S13002
thanks again
-los
los_inc is offline   Reply With Quote
Old 10-04-2008, 09:07 PM   #2
LongGrain
LongGrain's Avatar
its called a cam bolt. its how camber is adjusted with factory RUCA's
i dont know if it can be replaced with a normal bolt.
LongGrain is offline   Reply With Quote
Old 10-04-2008, 09:16 PM   #3
hailandkill
hailandkill's Avatar
hailandkill is on the path to ruinhailandkill is on the path to ruin
When are we painting your subframe pink? =D
hailandkill is offline   Reply With Quote
Old 10-04-2008, 09:21 PM   #4
Def
I'm guessing your car is HICAS. They have those weird weights on the bolts. You can order a non-HICAS S13 RUCA bolt from the dealer and lose that nasty weight.
And your bolt on spacers make baby jesus cry.
Old 10-04-2008, 09:33 PM   #5
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
my car has those too. i think its for adjusting camber for stock ruca's
lexus baby
5t341tH is offline   Reply With Quote
Old 10-04-2008, 09:38 PM   #6
los_inc
los_inc's Avatar
i wanna rip them out and just run a same size regular bolt since i have aftermarket control arms which allow me to adjust camber
thanks again
-los
Old 10-04-2008, 09:39 PM   #7
Def
thanks again
-los
Look at the slotted holes in your subframes. Then think about what a regular bolt would do in that hole...
If you want to get rid of the retardo weight bolt(which is Nissans poor attempt at vibration control), then order a non-HICAS eccentric bolt.
Old 10-04-2008, 10:04 PM   #8
Dousan_PG
Dousan_PG's Avatar
do NOT get rid of that bolt
or ur regular bolt will move all over and throw the cmber off
leave it
Aaron
Pink GodziRa
Old 10-04-2008, 10:18 PM   #9
los_inc
los_inc's Avatar
leave it
alright i guess it stays
thanks for all the help
time to paint it pink
-los
Old 10-04-2008, 10:24 PM   #10
projectRDM
projectRDM's Avatar
You guys all fail.
Buy large fender washers to fit on either side of the subframe to fit the recessed area, then use a regular bolt. Works fine, I do it one every car I put adjustable arms on. Eccentric bolts are shit, if they're overtightened they usually strip the washer and can't be removed easily.
As far as the weird bolt, it's not a HICAS only thing, a lot of S13s have them. I've seen them on probably 20-30 cars I've either worked on or parted out. I have no clue though what it is.
FORMERLY R240NA
Old 10-04-2008, 10:48 PM   #11
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
That's what I did. The fender washers fit perfectly, and I used hardened bolts from Ace Hardware.
Old 10-04-2008, 11:09 PM   #12
projectRDM
projectRDM's Avatar
Thank you. I like seeing other people who have common sense.
FORMERLY R240NA
Old 10-04-2008, 11:44 PM   #13
Def
You guys all fail.
The weight is Nissan's cheap attempt at more subframe vibration absorption. Like the rubber/steel mass dynamic vibration absorbers on the front of an S14 subframe, only more ghetto on the S13 version where they just used a couple of masses stuck around.
I'd be a bit worried if I was driving my car hard and the washer wasn't the exact diameter to fit in the recess. Too big and you're putting a huge shear stress around the RUCA mounting point.
A new eccentric bolt from Nissan probably isn't retardedly expensive, and you can adjust the RUCA to be as short as possible to maximize camber gain under travel.
Old 10-05-2008, 09:33 AM   #14
projectRDM
projectRDM's Avatar
The washers I use are thick, and I trim the sides down just a hair to fit tightly in the recess. Obviously it has to fit right or it has no value at all, but I do think some people would read 'washer' and just stick anything in there. That's part of the problem when coming up with solutions, not everyone uses common sense. You could also weld the washers in place which would really solve the issue. I've just been really against eccentric bolts ever since I had to drop a subframe to beat one out that was installed wrong and overtightened.
Plus, and this is only for people who really fail, taking it to an alignment place gives the technician an excuse to play with the bolt and not use the arm for what it's intended for because it's more complicated to do so. Hopefully most people use a competent alignment shop but there's plenty of shortcutters on here who don't. Giving someone two points to adjust seems to be a waste of time when only one is needed.
FORMERLY R240NA
