Old 10-06-2008, 01:26 AM   #1
Chuki91
Chuki91's Avatar
Chuki91 is making a name for him/her selfChuki91 is making a name for him/her self
Send a message via AIM to Chuki91
Missing Top hat for a coilover! Help!!!
So I plan to get rear S13 coilovers off of craigslist. The problem is one is missing a top hat. I asked the guy on what I can do about it. He said that I can just use one of my top hats from my stock suspension and it should work. Is the information that he gave me legit? Well let me know zilvia. I would highly appreciate it a lot. An "FYI" they are rear GP Sport GR-6 Coilover (black/purple/white ones)....to be precise! Well, LMK....thanks!!!
Chuki91 is offline   Reply With Quote
Old 10-06-2008, 02:55 AM   #2
Zhanshi
Zhanshi will become famous soon enoughZhanshi will become famous soon enoughZhanshi will become famous soon enoughZhanshi will become famous soon enough
They should work, but its probably not the best idea to keep using the stock mounts. The stock mounts are made of hard rubber and don't give the strut as much movement as a pillow ball mount. You might want to look into some rear pillow ball mounts (possibly Tein or HKS?)
Zhanshi is offline   Reply With Quote
Old 10-06-2008, 01:20 PM   #3
projectRDM
projectRDM's Avatar
Completely incorrect. The rear OE upper mount is steel. It does use a rubber bushing in the center and a rubber insulator below, but is it not a big chunk of rubber like the front.
The problem is the coilover pillow ball mounts are thinner and fixed to the shaft with a spacer, some coilovers are designed to use that exact that type of setup only. The old Apex'i WS Coilovers worked with OE mounts, but not a lot of others do. You'll have to see what you're working with and go from there.
FORMERLY R240NA
Old 10-06-2008, 11:48 AM   #4
Chuki91
Chuki91's Avatar
Thanks for the info "Zhanshi" To be exact I was planning to use the top mounts off of my KYB GR-2 suspension. well let me know zilvia! Thanks
Old 10-06-2008, 03:37 PM   #5
Zhanshi
Ah sorry about that, I took another look at the mount itself and it is just rubber sandwiched between steel. Thanks for pointing it out so quickly! Like projectRDM said, the OEM may or may not work. As for pillow ball mounts, you might want to ask a friend to borrow the rear set just to test fit. My rear pillow ball mounts were significantly shorter than stock.
Old 10-07-2008, 01:00 AM   #6
Chuki91
Chuki91's Avatar
Thanks guys. the information was quite helpful!
