Old 10-17-2008, 07:39 PM   #1
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
In need of some fast tech anwsers.
So.
I just swapped an s13 SR into a hatch a few days ago.
I bought the motorset from JonWayne (Sil-ABC) so I know it's legit.
So I pulled out the old ka...swapped in the SR..wired everything up.
everything seemed fine.
I cranked it over...fired up fine first time. w00t.
but It was sounding like a subbie...
I checked the coilpacks they are getting power to them. (pulse light)
I even tried replacing the coilpacks from my last motorset; which I new worked...but nothing changed.
and I replaced the coilpack harness from my last motorset; which I new worked...but nothing changed.
I checked the injectors aswell. (pulse light) I even pulled out the multimeter and the numbers were correct.
they seem to be getting power to them aswell.
The car is misfiring...and honestly...I'm stumped..
I checked the fuel sending lines...and they are sending fuel fine.
where should I be looking next?
I was thinking about the ecu wiring...
any help would be greatly appreciated.
EDIT*
I even put new iridium plugs in and gapped them at .28
#1 and #3 are the cylinders misfiring.
Ignitor is good. Coilpacks are good. No damage on the rubber ends. Spark plugs are not getting blow-by.
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 10-17-2008, 07:44 PM   #2
lflkajfj12123
did you check the plugs?
when you take out a coil at time does the engine keep up or does it drop
listen for each cylinder
see any fouling?
Old 10-17-2008, 07:44 PM   #3
cc4usmc
cc4usmc's Avatar
http://zilvia.net/f/tech-talk/199341...ia-blu808.html
This forum requires that you wait 120 seconds between reporting posts. Please try again in 115 seconds.
Originally Posted by s141996 View Post
is this exhaust california friendly? thnx lmk
cc4usmc is offline   Reply With Quote
Old 10-17-2008, 07:46 PM   #4
downshift_sideways
No Limit Soldier.
New plugs..forgot to mention.
Old 10-17-2008, 07:52 PM   #5
lflkajfj12123
correct gap?? .03?
how are the boots on the coils make sure no fouling or damage
could cause the spark to arc early (i've had this happen and it caused a misfire)
did you test spark by connecting the spark plug to the coil and then checking
not oh okay new plugs and i tested the coil?
Old 10-17-2008, 07:48 PM   #6
Om1kron
Om1kron's Avatar
sounds like some vacuum lines are hooked up backwards lol.
Wayne Edwards
https://om1kron.blogspot.com
Old 10-17-2008, 07:51 PM   #7
cc4usmc
cc4usmc's Avatar
I was going to say a vacuum leak, or some sort of leak period.
Old 10-17-2008, 07:58 PM   #8
downshift_sideways
No Limit Soldier.
^Yea.
New plugs..coilpacks are working fine.
Ecu threw code 55.
everythings okay.
vacuum lines are all hooked up correctly.
I might need to check the pinout from my ecu to the injectors.
#1 and #3 are misfiring.
Old 10-17-2008, 08:08 PM   #9
lflkajfj12123
sounds like that could be the problem
other than that i just think air / vacuum lines
Old 10-17-2008, 08:12 PM   #10
lflkajfj12123
maybe TPS of MAFS connections loose?
possible? check check
Old 10-17-2008, 08:14 PM   #11
downshift_sideways
No Limit Soldier.
TPS is fine.
That was one of the first things I checked.
TPS at closed throttle registers at .44 volts.
CAS is fine. If Jon never touched it ...it should be fine.
Last thing...Is to check the timing.
Old 10-18-2008, 02:41 PM   #12
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
TPS is fine.
that should be one of the first things to check. let us know what you find out
96Turbo is offline   Reply With Quote
Old 10-17-2008, 08:16 PM   #13
drftwerks
how much fuel is getting to engine, new filter?
giantroboteyes.wordpress.com/
Old 10-17-2008, 08:18 PM   #14
lflkajfj12123
i doubt its the filter lol
everytime i think thats the problem i replace it and it fixes nothing
Old 10-17-2008, 08:22 PM   #15
drftwerks
but it should always be done anyway
Old 10-17-2008, 08:32 PM   #16
downshift_sideways
No Limit Soldier.
Yea....
Fuel delivery should be fine.
Shitload of fuel squirted out as I did a fuel reading on it.
I'll try replacing that too while I'm at it.
Old 10-17-2008, 09:17 PM   #17
SDS13COUPE
SDS13COUPE's Avatar
SDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant future
What about your ignitor chip/wiring. I had a similar issue, but I tore the wiring apart and found that the shielding wire to my #1 coilpack was grounding on my signal wire. This caused a subie sounding misfire. I trimmed the excess insulation, and cleaned up the harness and after that no problem. I just tested continuity in the wiring and found it. GL.
SDS13COUPE is offline   Reply With Quote
Old 10-17-2008, 09:13 PM   #18
lflkajfj12123
lol dude did u take out the fuel pump fuse first??
Old 10-17-2008, 09:41 PM   #19
Mi Beardo es Loco
Mi Beardo es Loco's Avatar
Location: A place where boob jobs ruined the best thing about being a fat chick.
Mi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfection
had that problem in my Diesel. Ended up being a kinked vaccum line. Unlikely but worth a look.
Originally Posted by JVD
I'm a street thug straight outta compton...
Any of you guys watch gay porn?
Mi Beardo es Loco is offline   Reply With Quote
Old 10-17-2008, 10:22 PM   #20
silviaguy240
silviaguy240's Avatar
physically unhook your injectors one by one. dont just use a pulse light, if they're clogged they arent shooting fuel!
Old 10-18-2008, 01:12 AM   #21
downshift_sideways
No Limit Soldier.
^ I actually took apart each injector and inspected them, and replaced the O rings on each one. I let the car run while unplugging each injector...as I pulled out #1,3. Nothing happened and the car didn't want to die.
Since #2,4 are working properly(and stumble when pulled out), I swapped #2 with #1...and still no stumbling when I performed a check.
I believe the problem remains on the wiring.
Tomorrow I'm tearing apart the entire wiring harness and checking for any faulty wires.
I'd might as well just tuck all my wiring while I'm at it.
S13SDCOUPE: I actually replaced the entire coilpack harness with the one from my last motorset that I knew ran perfectly well...and the problem still remains..I believe the problem might be somewhere after the coilpack sub-harness.
I'll update this thread tomorrow.
Old 10-18-2008, 04:36 AM   #22
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I spy the timing is off...double check the timing.
CLICK HERE!!!
Old 10-18-2008, 07:10 AM   #23
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Timing! I knew that was it! Even when it was the bears, I knew it
was the timing.*
Check timing x2.
*P.S. I don't really know if it's timing or not, but it sure sounds like it. Good Luck!
HalveBlue is offline   Reply With Quote
Old 10-18-2008, 07:13 AM   #24
downshift_sideways
No Limit Soldier.
^lols!
Thanks <3
I'll check it later today.
Old 10-18-2008, 07:14 AM   #25
Tearlessj
Tearlessj's Avatar
Werd, timing was the first thing that came to mind. Good luck man, I know that shits frustrating.
Nagasaki Motors
Friends help you move. Real friends help you move bodies.
Tearlessj is offline   Reply With Quote
Old 10-18-2008, 09:42 AM   #26
SDS13COUPE
SDS13COUPE's Avatar
Just use a dvom and test continuity through that subharness just to make sure. I just rewired my friend's subharness that he bought as a "drop-in" swap, and it was way off. Just double check it to be safe. GL.
Old 10-18-2008, 11:35 AM   #27
ThatGuy
Admin Asshole
ThatGuy's Avatar
Tech Question in Off Topic?
Nope.
Moved..................
Old 10-18-2008, 02:05 PM   #28
downshift_sideways
No Limit Soldier.
^Oh thanks Barry <3
