Old 02-04-2003, 11:39 AM   #1
A Dying Devotion
A Dying Devotion is an unknown quantity at this point
Send a message via AIM to A Dying Devotion
200k mile maintanence
Well my 240 just hit 200k miles and I am gonna flush out the coolant, change the oil, get rid of the gay airbox and put a cone filter, new spark plugs, new wires anything else that could be important now such as new fuel pump, oil filter etc?
Your my blessing in disquise, you make me realize, just where I want to be years from now.
A Dying Devotion is offline   Reply With Quote
Old 02-04-2003, 11:57 AM   #2
DSC
New Title
DSC is an unknown quantity at this point
oil filter should be changed every time the oil is changed.
Other things, rotate tires, tranny and differential oil change, distro cap/rotor/plugs/wire, fuel filter. Good idea to double check to make sure all your lights work. Check tire pressure. Retorque lug nuts. All I can think of now...
Congrats on hitting 200k!
DSC is offline   Reply With Quote
Old 02-04-2003, 12:01 PM   #3
s14 RL
s14 RL is an unknown quantity at this point
Send a message via AIM to s14 RL
Check your belts too (alternator/fan, power steering, compressor)
s14 RL is offline   Reply With Quote
Old 02-04-2003, 12:53 PM   #4
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
Brakes...
...check the pad thickness and replace if needed
...check the rotor thinkness and replace if needed
...check the fluid level, and if you haven't before, flush the fluid
Might as well do the clutch at the same time while you're in the bleeding mode. Same tools, same procedure, same fluid.
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 02-04-2003, 12:58 PM   #5
A Dying Devotion
Hey thanks guys I get paid tommoro ill do all this stuff tommoro as well.
