![]() Join Date: Jun 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
No BOV
So I just got my motor running right, and there is an event in 1 week.
I have a v-mount set up, with no Blow off Valve. its jsut a stock Redtop, stock turbo with basic bolt-ons. how good or bad is it to run no bov?? Also what is good oil pressure at idle? and pressure at full throttle? Thanks for any help. I hate starting new threads.
AERO-K GARAGE |
![]() Join Date: Oct 2006
No bov is fine on any boost.
So many of us have run without it for years - no problems. I run one now just because im a ricer.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
![]() Join Date: Jun 2003
Yep.
T25's are cheap. Only reason I run one is Disco potato turbo's aren't that cheap. and I run like 20lbs. No BOV is awesomer though.
![]() Team Pterodactyl SHARK ATTACK!!! LookoutDrift |
wow, I remember gettina a boner from that Supra back in the day, and always wondered what BOV it had. LOL
thanks for the help everyone Now my second question. what is good oil pressure at idle?? and pressure at full throttle?
AERO-K GARAGE |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
BOV's are lame unless they are re-circulated. They sound soooooo effin annoying. They are also not 100% necessary, especially if you have a cheap ass t-25 or t-28.
#14 |
![]() Join Date: Jan 2007
Oili pressure:
Approximate Discharge pressure : kPa (kg/cm^2, psi) Engine speed at idle more than 78(0.8,11) Engine speed at 3000 rpm 412-481 (4.2-4.9, 60-70) EDIT: that's for a stock KA btw, i don't know about SRs or with any modifications you've done.
#15 | ||
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
numbers don't mean anything without units... you could say just your pressure is just 20. Is it 20psi or 20kpa? A simple mistake like this costed NASA the Mars Polar Lander some years ago.
HouseBuyers365.com Quote:
#16 | |
Yeah i just copypasted the fsm. how is a kg/cm2 a kPa?
#17 |
1 kPa = 1000 N/m2 , where a N is for "Newton" and it is a force unit ( not a mass unit, as Kg ), where 1 Kg exerces 9,81 Newtons under earth gravity ( 1 Kg * gravitational acceleration (9,81m/s2) )
so, simply, 1 kPa is the force exerced by 1,02 Kg on a square cm, on earth. and roughly, 100kPa = 14,5 psi |
#18 |
wow, I barely understand what the fuck it is you just posted. just lookin for some simple numbers people see on their gauges.
thanks for tryin to help though
AERO-K GARAGE |
#19 | |
sorry i just quoted the FSM. It says above 11psi at idle and 60-70 psi at 3000 rpm.
#20 |
ok man i have a ka-t but might be same concept in normal terms. 18psi at idle when warm around 40psi when cruising. And as you get up in rpm's oil pressure gets higher.
#25 |
awesome, im loving these responses. I feel like this whole aftermarket BOV thing is just some conspiracy to spend more money.
So now thats cleared up, can I get a few more responses to the oil press. question? what do you guys see at idle and full throttle? just wanna be safe as I start driving the car this weekend.
AERO-K GARAGE |
#26 |
It *theoretically* could *possibly* damage the turbo over time. In reality however your turbo will almost certainly take a shit for other reasons long before not having a BOV does it. If I had an expensive turbo I would run a BOV just to be safe, but with a t25 or 28.....whatever.
#28 | |
but bras are about keeping more important things up there's the difference
what good is easy access to something made worse by it?
