Couple questions (lower wiring harness/body harness, pulley question)
I've done so much much trying to do my sohc to dohc swap. I have run into some problems and am extremely frustrated.
First, are there 2 lower harnesses? I grabbed one off an auto 240 at a junkyard that connects from battery to alternator/starter/to 1 plug on the tranny. There are still like 4 plugs on the tranny and 2 plugs coming out of the fuse box. What goes to them? 2nd, I looked at the body harness connector by the ecu that I have to replace with a dohc one for the swap. Unless you can take it off the bracket and you have about a foot of extra slack, I don't see how it's possible to cut that connector and rewire a dohc one on without taking the entire dash off. any input? 3rd, I removed the a/c and p/s. Now I need a belt to go around the crank pulley and water pump. I have to wrap the belt around a tensioner too right? That's what I was told. And if so, there's no tensioner that is aligned with those pulleys. Pretty stumped on that one. |
is your car an original 5 speed?....i did this swap...easy..i need to know first if its original manual?..
anyways 1)there is only one lower harness..if your car was already manual u can use the same sohc lower harness and put it on your dohc..this will solve your problem with the plugs on the fuse box... 2) the question isnt really clear..but all u have to do is..get the body harness plug on your sohc top harness and solder it to your dohc top harness. .match up colors..some are unused..then u put it through the firewall and plug in the big blue to ecu and other plug to body harness.. 3) you need to have ps pretty much...alternatives are eletric water pump (expensive)...or just put the ps pump back on and cap off the end with oil in there... Last edited by Slammed Assassin; 12-30-2008 at 02:55 AM.. Reason: added info |
![]() Join Date: Dec 2002
There is both a manual and auto lower harness, and the SOHC and DOHC harnesses are different. Use your existing harness and shorten the alternator wiring, clip off and throw away the P/S pressure switch plug. Or you can use a DOHC manual harness and plug it right in. The remaining wiring for the transmission isn't really needed anyway, run a search, there's plenty of info on this swap.
Take the glovebox out, gives you a lot more room to reach the dash plug.
my car is originally a m/t but it doesn't matter because when I bought the car the tranny was gone along with the lower harness and clutch assembly, etc. so pretty much ditch the a/t harness and get a m/t one? I have to replace the connector that's part of the body harness correct? not the connector coming off the plug for the ecu, cus that's already a dohc connector. So ya that connector coming from the body harness seems almost impossible to have room to solder. And just throw on the p/s for the use of the pulley only? thanks
u really don't need the tranny harness. all its good for is to trigger your reverse lights. so if u don't care about that, don't waste your money. only thing to kinda worry bout is ur speed sensor. but even then... just tells ur car when to set off ur speed limiter.
the search will reveal these answers. ive been through this myself. also, check the FSM. u can find the pdf around here to dlllll |
![]() Join Date: Dec 2008
i got the same problem the plug to the dashborad it doesnt plug into my dash and my car use to be a sohc how do i slove the problem of connecting the dashborad plug for the twim cam harness
![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
It says right above man, you need to cut the plug off the SOHC harness and solder it onto the DOHC harness. Done
I never know what to put here. |
ok im still pretty confused about what to do about the pulley from the water pump to crank. the oem pulley i go from the a/c to water pump to crank i believe. i dont have a/c anymore....
Not on any KA I've seen. The A/C has it's own belt. The water pump is driven off the crank along with the P/S pump, without it you have no way to tension the belt.
ok i got the pulley situation sorted out and the body harness. I hook up the harness to the ecu and am getting no power. i think the problem may be the auto tranny harness. there are 2 connectors just coming out of the fuse box going to no where...i would assume the manual tranny harness would take care of those connectors??
#11 | |
