Old 01-04-2009, 12:13 AM   #1
astrophixvox
astrophixvox's Avatar
astrophixvox has a spectacular aura aboutastrophixvox has a spectacular aura aboutastrophixvox has a spectacular aura aboutastrophixvox has a spectacular aura aboutastrophixvox has a spectacular aura aboutastrophixvox has a spectacular aura about
SR Want to rid of this damn push button!!
Heres my set up....
90 s13 w sr redtop...
I've got a push button to start my car but it's always really rough to start and from what i've searched....its better to start the car with the key. I'd like to do this but never touch much on the car that deals with the electrical aspects. I'd like to know what to do to get the car started with the key.....and if there is anything i should be looking out for. I don't want to go in there and burn something out and bring unwanted problems. Just tired of having to press the damn button four times to get the car started. Thanks guys!
astrophixvox is offline   Reply With Quote
Old 01-04-2009, 12:57 AM   #2
reinvent
reinvent is an unknown quantity at this point
Originally Posted by astrophixvox View Post
Heres my set up....
how do you turn accessory and "on" on?? do you use key at all? find where original wires were cut and reattach them.
you can see ignition switch in this picture.
there is constant power coming in and then the ignition switch has 4 wires going out ie accessory, on , and two wires for start
the harness wires will be different from the wire colours right at the switch. switch unplugs from harness. they may have used push start because the ignition switch was not working. solder the wires back together.
reinvent is offline   Reply With Quote
Old 01-04-2009, 02:19 AM   #3
astrophixvox
Thanks a lot! I learned that they put a push button on my car out of laziness. Yes I am using the key for the accessory. Should I continue with the instructions you gave me? Thanks for your time and help!
Old 01-04-2009, 02:53 AM   #4
reinvent
have a look at the wiring for the push button. I'm guessing they cut the wire that goes to the starter and the button connects the wire to another wire that has 12v+. find out how many wires go to button and where the power wire gets it's power from. get rid of power wire and reconnect starter wire to where it was cut. if you have a camera take some pictures.
Old 01-04-2009, 03:48 AM   #5
astrophixvox
Looks like it's two wires. One to the battery and one To the starter. Should I take the wire going to the starter and run that one to the ignition? And ditch the one going to the battery.
Old 01-04-2009, 04:49 AM   #6
yokotas13
yokotas13's Avatar
if you put a relay in there it wont be hard to start anymore
yokotas13 is offline   Reply With Quote
Old 01-04-2009, 05:02 AM   #7
astrophixvox
Thanks friend if my ignition ends up being bad that will be my alternative.
Old 01-04-2009, 05:09 AM   #8
astrophixvox
From the way the four wires look in the pic above coming out...which is the one that goes to the starter? Top left,right? Bottom left, right? Thanks for all the help!
Old 01-04-2009, 07:58 AM   #9
reinvent
Your colours will not be exactly the same.
the wire colours may change in about a foot from that picture where it plugs into the harness.
white with red stripe- is power coming in
blue- accessory
black with green stripe-"on" position
black with yellow-start-goes to fuse
black with white-start goes to interlock relay and then starter(it changes to black/yellow as it leaves interlock relay to go to starter)
Easiest thing to do is to look at which wires have been cut. If only one wire is cut, it will be the wire that goes to interlock relay/starter.
There are two wires that get power when you turn to start but they may not have used second wire.
Old 01-04-2009, 05:14 PM   #10
astrophixvox
Cool I'll look for that wire and try and get it connected. Meanwhile the car is starting better by turning the key all the way (like im starting the car) and pressing the button. Thanks for all the help!
Old 01-06-2009, 10:22 PM   #11
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
there's many cleaner ways to doing this when you know what you're doing but here's the easiest for you
attach a long wire to the thick black and yellow striped wire that goes to the ignition switch.
run that wire all the way to your starter solenoid wire which is the little black/yellow wire coming off your starter
voila
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 01-07-2009, 09:48 AM   #12
ixfxi
Guest
Posts: n/a
start signal for the ecu is not connected, simple as that.
Old 01-07-2009, 10:28 AM   #13
Z U L8R
Z U L8R's Avatar
his problem is the motor's not turning over from what i read. if the start signal wire that goes to the ecu which is the orange wire on the brown (since his chassis is a 92) plug behind the glove box isn't connected his car may not run, but his starter will still turn the motor over.
truthfully, there's probably something he missed with the wiring as far as the park/neutral switch, or the clutch inhibitor switch, but an easy bypass is to do what i mentioned above.
at that point the motor will turn over with the key, if it doesn't start up and run then you have other gremlins and we'll go from there.
Dave
Old 01-07-2009, 11:08 AM   #14
reinvent
do you happen to know what the start signal triggers/does?
Old 01-07-2009, 12:10 PM   #15
ixfxi
Guest
Posts: n/a
yes, it lets the computer know that the car is trying to start - it makes starts a lot easier.
if the start signal wire that goes to the ECU is not connected, then the car will only start if you crank it long (maybe 5-10 seconds) or if you open the throttle with the gas pedal.
i had mine disconnected for years, its a nice security feature knowing that i am one of the few people that can start my car since i know its quirks.
mike
ps: i dont remember ANY of the factory plugs, connectors or wire colors since i completely re-wired my entire car from scratch. the only way i recall color-codes or harnesses is through my spreadsheet as i documented it all in there.
Old 01-07-2009, 06:49 PM   #16
astrophixvox
You guys help has been great! I've been able to pass on the help to few others around here at home. Thanks!
