Old 02-18-2003, 05:23 PM   #1
Heartwork
Heartwork's Avatar
Heartwork is an unknown quantity at this point
any other suspension parts needed?
i just ordered some CUSCO parts for my S14 240sx..
- Comp Zero 2 coilovers
- Rear sway bar
- front upper strut bar
- rear upper strut bar
im also planning to go wide on the rims, 17x9 with a low offset or so......
now i know there are camber correction kits when lowering our cars, so what else do i need? Battle Version/Cusco adjustable rear upper arms? tension rods i need? foward links? toe links? also, due to the fact my car does have 110K miles on it, i would like to replace all bushings that arent included with the stuff i just purchased....what other known bushings can be replaced while im at it?
thanks....
Heartwork is offline   Reply With Quote
Old 02-18-2003, 08:08 PM   #2
Tubed4evr
Tubed4evr is an unknown quantity at this point
The ones that I can think of off hand are: front control arm bushings and rear lower control arm bushing. The rest would be taken care of if you buy all that stuff you listed with question marks. You can also replace just bushings on alot of that stuff if you want (i.e. TC rods and Rear upper control arm bushings).
Don has most bushings made for S13
Tubed4evr is offline   Reply With Quote
Old 02-18-2003, 08:12 PM   #3
kanekz
kanekz's Avatar
kanekz is an unknown quantity at this point
Also you can get Sway bars Front & Rear. If your TC rods are going out, you can get pillowball tension control rods or replace the bushing (which I did from PDM-racing.com). SUBFRAME SPACER is also a good mod for the price.
kanekz is offline   Reply With Quote
