![]() Join Date: Jan 2007
Build Thread : Silvia 500HP +++ Drift Machine
Hey guys
thought id post some shit up... Anyway, after going to japan in 07 and buying a 180sx, competing in D1 SL , MSC etc and destroying the body and stuff, when i brought it back i drifted it for a few meets then bought a stock 91 Q's silvia CA18 DE Automatic. I transplanted all my SR stuff into it... S14 subframe,ATS carbon LSD, 4.6nismo C&P. 5 stud, Dogbox ,twin plate,heyman KNUCKLES,jic coils,cage,brides,etc..etc.. it had fairly good shit on it that i put on over in japan Now.. recently my engine blew up due to a rocker breaking etc... it made 470HP at the flywheel *281rwkw* at 16psi of boost.. which is fairly good for something with more power from 0 RPM to 8000 then a standard engine ![]() Here's some pics of it drifting interstate (adelaide) - p.s im from Melbourne Aus so its about an 9 hour drive by car. Idrove it up and competed.. however got knocked out right away due to playing games lol.. ![]() ![]() anyway back then it was only making 240rwkw @ 17psi of boost.. since then i have installed a carbon fibre tailshaft by ACPT in the states, HKS twin spark CDI igntion system and a custom made steam pipe ceramic coated manifold + blitz SBC Spec R boost controller - all this bumped up the power to 281rwkw with 16psi of boost. the motor was apparently forged and stuff, but when it blew up .. noticed it was just standard with the usual bolt in tomei procams,valve springs,solid lifters,hks headgasket,greddy plenum and tomei sump.. it was suppose to have forgies andwhat not and have toda liners bla bla.. i got jibbed but whatever the motor didnt blow up in japan which was the most of my concern... ohhh in japan i used the AX53b70 p22 for drifting ... then put the K3-450R on it before shipping it off to australia ![]() now it is getting :::: DG-5 GP SPORTS Pro coilovers all around brand new.. 2.2L stroker engine with JUN liners Full respray ( except the bay as it's pretty neat there ) Tripple plate Power Enterprise clutch. Im aiming for well over 500HP on 16-17psi... this is on pump gas on a dyno which reads quite low compared to others - there is lots of funny dynos in australia but Sam @ www.drdrift.com.au knows his stufff and tunes my stock ECU better then most others in australia ... so i stick with him. Full spec of the car is below 1991 Silvia. SR2.2 JUN 2.2L pistons 87mm ceramic coated short skirts JUN crankshaft 92mm Manley Pro rods JUN Steel bore sleeves Cosworth 1.5mm headgasket high CFM head Brian Crower valve springs Titanium retainers Billet 262/262 12.0 camshafts Tomei Solid Lifters Tomei Rocker Arm Stoppers JUN bronze valve guides Powertune Steam pipe manifold, Ceramic coated Blitz K3-450R 10cm turbo kit with braided boost hoses Blitz 850CC injectors HKS CDI Twin Spark Blitz SBC ID Color Spec R Boost controller oversized waterpump pully R33 clutch fan Riverside s14 rear end setup 2way Carbon ATS lsd nismo 4.6 crown & pinnion Power enterprise tripple plate solid clutch kit Quaife (UK) straight cut dog box ACPT Carbon tailshaft Blitz Intercooler kit 75*300*600 Super-made custom built 3 core radiator. Silicone Radiator Hoses Greddy oil cooler kit with relocator Supermade bullet exhaust Thrash racing drivers seat Bride Brix 1.5 passenger seat 3x hks gauges on the passenger side in the dash(oil temp,pressure, water temp) 1x SARD boost gauge 17x9 front CST wheels in gunmetal 4x18x9.5 +15 rears CHROME 4x18x9.5 +23 rears bronze Tyres : F - 215/40/17 AD07 Advan Neova's R - Achilles ATR sport 235,40/18 GP Sports Gmaster PROs DG-5 coilovers Tein tie rods Hey Man Products KNUCKLES 5 stud conversion r33 brakes... Cusco Camber Arms Cusco Toe Arms Silk Road Traction Arms D-MAX Hub's with new wheel bearings 9 point full cage Supermade headlight covers,indicators,parkers,clear lights. Origin FRP doors ( 4KG each ) new steering rack bushes ( stiffer then stock ) I will be posting pics of everything once iget my engine back from the builders... (hoping two weeks max) Here it is after the engine blew up lol... getting ready to go to the panel shop.. ![]() IF anyone has any questions or ideas please let me know
![]() Last edited by Teambadrun; 01-21-2009 at 05:43 AM.. |
![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 5 reviews
I didn't see what size turbo you were thinking of. 500whp at 16lbs is going to very hard to do. Even a super efficient setup would have a hard time doing that. Maybe 500whp at 22lbs is more reasonable. But if you were only building 16lbs max boost to make 500whp, you would have a very big and laggy turbo instead of a reasponsive turbo making the same power.
I don't know what turbo you are thinking of though. |
#3 | |
And now with a 2.2L stroker it will be even more responsive. I don't plan on making 500rwhp... haha this car is used for Drifting so this turbo stays so around 500 crank HP is the goal with maybe 18-19psi of boost.. but i dont see why it wouldnt make 500HP(only 30hp peak more) with the same boost level, considering the old engine was a stock bottom end ![]()
![]() Join Date: Dec 2007
![]() ![]() ![]() ![]() Feedback Score: 16 reviews
I think you'll need more than 16lbs aswell, but I'd like to be proven wrong. =D
Banana boat chronicles |
#5 | |
yeah im from base, ha, i had a dark blue onevia, and yeah im good friends with chris. im pretty sure i met you when you were here, when i first started building my 13
maybe lol.. i was with scott.. helping him build the cefiro for matsuri
Ill be back in Tokyo in mayish.. bought a 180SX to drift again haha
ohhh
haha, awesome, my new car will be done for sure, its a bare metal chassis right now, just got it stich welded, in a stall at the hobby shop onbase heres a vid of me at the nov 08 matsuri YouTube - Nov 2008 Drift Matsuri in my old car, which was my missle LOL
AWSOME!!
Well maybe i can stay at your place on base!! just sign me in ![]() Because Jesse corado is now back in USA and i was staying at his place last time for abit ![]() ![]() ![]() ill add you on msn actually.. talk there ![]()
You aussies really do know how to build a proper NissIn.
seriously rock the fuk on! ![]()
Like Me on FaceBook ![]() |
