Old 02-23-2009, 12:53 PM   #1
Iron_Zenki
Iron_Zenki's Avatar
Iron_Zenki is an unknown quantity at this point
s14 Power window do not work anymore
Couple of weeks ago my passenger window would no longer roll down. I kept on hearing clicking, then just yesterday my drivers side window would no longer roll up. I looked every were to see if anyone had the same issue and many did but the opposite way it happened to me my fuses are fine any suggestions?
Iron_Zenki is offline   Reply With Quote
Old 02-23-2009, 01:00 PM   #2
S14TEENZ
S14TEENZ's Avatar
S14TEENZ is an unknown quantity at this point
window switch?
power window amp?
window motor?
becareful 95 and 96 switches are different.
S14TEENZ is offline   Reply With Quote
Old 02-23-2009, 01:06 PM   #3
Iron_Zenki
Iron_Zenki's Avatar
I noticed that When i opened my amp it clicks, I see no burns it just might be the motor :/
Old 02-23-2009, 01:10 PM   #4
WIKID S4TEEN
WIKID S4TEEN's Avatar
WIKID S4TEEN is making a name for him/her selfWIKID S4TEEN is making a name for him/her self
most likely power window amp
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 02-23-2009, 01:11 PM   #5
burgerwitfry
burgerwitfry is an unknown quantity at this point
what year is your car 95, 96? i think its probably your power wires coming off the motor are fried, thats what happened to me b/c motor got really hot and toasted it.
burgerwitfry is offline   Reply With Quote
Old 02-23-2009, 01:12 PM   #6
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
if you really want, u could take a spare battery and run juice directly to the motors and see if it does anything.
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 02-23-2009, 01:17 PM   #7
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
if you hear clicking your amp/switch is doing its job
90% its your motor that gone bad.
if thats the case i can fix it for $40 shiped
first feed power directly to the motor plug. Don't worry about polarity b/c either way it will go down or up
built ka-t
importdude is offline   Reply With Quote
Old 02-23-2009, 01:38 PM   #8
Iron_Zenki
Iron_Zenki's Avatar
s14
it is a 95 another thing I noticed was that the wires connected to the window control become hot. I will check all the wires tonight, Will it make a difference if I get the amp and control until from my friends 97?
Old 02-23-2009, 02:38 PM   #9
projectRDM
projectRDM's Avatar
Yes, there is no amp on 96+ models and the door harness plugs are different.
If the wiring gets hot, the motor is seeing resistance, it's probably burned up. Hook a battery directly to the motor, but put a fuse inline on the positive lead. If it's indeed dead you could short the battery out while you're holding it.
FORMERLY R240NA
