Old 03-07-2009, 10:36 PM   #1
skylindrftr
skylindrftr's Avatar
Trader Rating: (26)
skylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfection
Feedback Score: 26 reviews
z32 brake clearance question
No this isn't about rim clearance. Moving on, I am putting 300zx iron 30mm cals up front and my buddy gave me some 30mm rotors from an alum setup. He told me they were machined 1mm down on both sides when resurfacing. I put them on the car to test fit and there is a god awful amount of space between the pads and the rotors (yes I know it will compress when the pedal is pressed). I was wondering if this was safe, I am going to the track in about a month or so, should I just buy new rotors?
Pics:
skylindrftr is offline   Reply With Quote
Old 03-07-2009, 10:51 PM   #2
S14DB
AFC #1
S14DB's Avatar
Do you have a Caliper(Ruler) to measure how thick the Rotor is?
Old 03-08-2009, 12:48 AM   #3
skylindrftr
Trader Rating: (26)
It is slightly thicker than a q45 rotor, I know that much, I'll take a reading tomorrow and see what it is.
Old 03-08-2009, 06:19 PM   #4
skylindrftr
Trader Rating: (26)
Okay the rotor thickness is about:
28.5 mm
Old 03-08-2009, 10:06 PM   #5
S14DB
AFC #1
S14DB's Avatar
28mm is the minimum. You'll be fine but I don't think you will be able to resurface them again.
Old 03-09-2009, 12:02 AM   #6
skylindrftr
Trader Rating: (26)
Cool thanks s14 db =)
