Old 03-10-2003, 01:21 PM   #1
normaspirated
normaspirated is an unknown quantity at this point
Send a message via AIM to normaspirated
Unhappy Clutch help?
I think either my clutch is fried or there's something else that's wrong. Two nights ago, I was driving home at like 5 in the morning. There was nothing wrong at the time. That same morning I had to go to work at 7 am . I started my car and let it warm up. After about 10 min., I started to leave to go to work. I attempted to put it in reverse, but it wasn't going in. So, I kind of forced it in and it grinded. I took it out of reverse and tried putting it in the other gears. The weren't getting in there. I had to press the clutch a couple times before it would go in smoothly (the shifter getting in gear). I thought nothing of it and went to work. When I was leaving work to go home, it was doing the same things again (not getting in gear as if I was trying to shift without pressing the clutch). I got home and I started to feel a bit concerned. So when I started my car again to go somewhere, the clutch was light as a fuc**** feather. There was like NO resistance at all. Oh yeah, I can't put it in gear anymore because I'm pretty sure the clutch isn't engaging with the flywheel. So, what do you guys think? Sorry for such a long post.
And try to be nice to my sisters. It's very hard on me to have you fighting all the time. -Marge
Oh, OK Marge, I'll get along with them. Then, I will hug some snakes...yes! Then, I will hug and kiss some poisonous snakes ... -Homer
normaspirated is offline   Reply With Quote
Old 03-10-2003, 01:31 PM   #2
AKADriver
AKADriver's Avatar
Sounds like the clutch master cylinder. Sadly, a pretty common problem.
Old 03-10-2003, 01:39 PM   #3
normaspirated
S.O.B. *sigh* Can you give me an idea of how much it would cost to replace a clutch master cylinder? *angry*
Old 03-10-2003, 01:48 PM   #4
HaLo
from Canada, eh!
HaLo's Avatar
not much.
a rebuilt master cylinder here is 70$cdn... that's roughly 50$ your currency.
add 1-2 hours of labor or do it yourself and voilĂ*!
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 03-10-2003, 03:46 PM   #5
DamnedButDetermined
DamnedButDetermined's Avatar
DamnedButDetermined is an unknown quantity at this point
first get a friend over to your house. Wiggle yourself under the car and have your friend pump the clutch. ( if it doesn't get stuck to the floor) Once he pumps it a few times you should be able to see if the slave cylinder is leaking. If not then check the master cylinder. (it doesn't matter what order you do this)
Mine would get stuck to the floor and fluid would leak out of the slave cylinder. I got a rebuilt one for $24 and it fixed the problem!
DamnedButDetermined is offline   Reply With Quote
Old 03-10-2003, 05:22 PM   #6
nrcooled
nrcooled's Avatar
nrcooled is an unknown quantity at this point
Send a message via Yahoo to nrcooled
these are very cheap and easy fixes so don't sweat it Get yourself a friend and a Chilton's manual and you will be on your way in no time at all
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP
nrcooled is offline   Reply With Quote
Old 03-10-2003, 09:30 PM   #7
nismofeind
nismofeind is an unknown quantity at this point
its one of you cyclinders just make sure you know which one. slave is on the tranny and its about $34. master is next to your brake master cyclinder and its abour $50.
mine was the Master. it works great now.
mine wasn't leaking however i bleed it once and it was a tad better. but when i changed my MC i took out my comfort box(a box with 3 lines runing in to it one from MC, one nylon hose and one to my Slave.) that is known to trap air. take it out bend the MC line to the slave line and they screw right in to each other that should solve your problem but will give you a slightly harder pedal.
nismofeind is offline   Reply With Quote
Old 03-10-2003, 11:49 PM   #8
normaspirated
Thanks for all the replies guys. Well, its obvious its not the clutch...so...I'm going to go ahead and check the clutch clylinders. Hopefully, changing either one of these (master or slave) is cake to fix!
Old 03-11-2003, 02:30 AM   #9
adey
adey's Avatar
adey is an unknown quantity at this point
To see if its your master cylinder, look around your clutch pedal for fluid, and look around the MC area under the hood for leaks. If it's damp around any of these areas, it's your MC. If not, it may be your slave cylinder, which is under the car on the passenger side, near where the tranny and engine mate up.
Good luck; changing the MC is an easy fix, it's just annoying to have to get under the car and bleed the damn thing when you're done! =)
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 03-11-2003, 06:06 AM   #10
Fireball240SX
Fireball240SX is an unknown quantity at this point
Send a message via AIM to Fireball240SX
My Clutch Master Cylinder just went out last week u can get a cheapo at Advance Auto Parts for $30 and it took less than 45min
2 Liter is my Weapon of Choice
Fireball240SX is offline   Reply With Quote
Old 03-11-2003, 08:29 AM   #11
normaspirated
Really? What tools would I need exactly? Could I do it by myself w/o any help from anybody? Sorry for all these questions. Sometimes this car gets me so frustrated that I want to get rid of it . But, I don't want to go back to any FWD vehicle. Thanks for the replies.
Old 03-11-2003, 01:43 PM   #12
DamnedButDetermined
you can do both of them by yorself, but you will need a friend when everything is installed to work the clutch pedal when you bleed the lines. Good luck
Old 03-11-2003, 02:19 PM   #13
MorganS13
MorganS13 is an unknown quantity at this point
i changed both my slave and master cylinder for less than $100, i've heard its around $250 at a dealer to have them do it. take it from me, if i can change them so can u
MorganS13 is offline   Reply With Quote
Old 03-11-2003, 03:32 PM   #14
the head
the head's Avatar
there are two nuts on the MC plus a pin that needs to be pulled at the top of the clutch pedal in the car and the one line going down that's it for the MC
slave cyl is two anchor bolts and one line
Old 03-17-2003, 09:56 AM   #15
normaspirated
Update:
Well, when I said that there was fluid in the reservoir, I was wrong I just assumed that the reservoir was full because it looked like a dark purple that took up the shape of the reservoir. Well, I pryed off the cap and there was NO fluid. I poured in some brake fluid up to max and it still DID NOT solve the problem. I checked underneath near the pedals to see if there's any fluid leaking near there and there wasn't any. So, right now there's fluid in the reservoir and the clutch pedal is still VERY light to push down on, but does go back up to the original position when I dump it. Do you guys think it's just the slave cylinder? Help me out! Thanks guys.
-Nissan total newb
Old 03-17-2003, 10:45 AM   #16
MorganS13
you have to get a friend and bleed the system. try and search and i'm sure you can find a procedure somewhere on here. its not too hard at all, sounds like you have air in your system and you'll wanna check your slave cylinder to make sure its not leaking.
