Old 03-10-2003, 11:43 PM   #1
Digity
Digity is an unknown quantity at this point
Push through or Pull through MAFS on SR20det
Anybody have ACTUAL dyno #s to show that Push through MAFS on a SR20det is better?
Digity is offline   Reply With Quote
Old 03-11-2003, 12:08 AM   #2
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Draw through vs. blow through.
I don't think there is a difference in them. It mainly allows the engine to run an atmospheric bov w/o stumbling after the shift.
-Jeff
Whatup?
Old 03-11-2003, 12:29 AM   #3
Jsquared
Jsquared's Avatar
Jsquared is an unknown quantity at this point
the only boosted car i've driven (dad's modded Porsche 944 turbo) has it's stock BPV vented to atmosphere (long story... essentially the BPV return flange on the aftermarket intake for the new MAFS (draw-through, stock location, better MAFS) didn't line up so the BPV is venting to atmosphere with the flange blocked off) and it never stumbled between shifts... did make a nice lil' fireball out the exhaust though (test pipe + B&B Tri-Flo + vent to atmosphere = cool flames)
Jsquared is offline   Reply With Quote
Old 03-11-2003, 05:32 AM   #4
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
you can still use the "draw through" set-up with a open atomsphere BOV...you just have to make sure that the BOV is shut at idle...if not you will run into problems.....
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 03-11-2003, 08:15 AM   #5
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
Exactly...that whole stumbling at idle thing is a myth.
piston type BOV's usually have that problem. Like Jonathan said as long as your bov is shut at idle you won't have any problems.
Driftec
www.midatlantic240sx.com
Foxcolt is offline   Reply With Quote
Old 03-11-2003, 10:28 AM   #6
Jeff240sx
I hate you too...
Jeff240sx's Avatar
I was talking about the instant richness right after the shift...
-Jeff
Whatup?
Old 03-11-2003, 10:31 AM   #7
Foxcolt
Foxcolt's Avatar
-Jeff
ok, does that acutally cause any problems that would warrent the effort and money to convert to a blow through system? or even a speed density system?
Driftec
Old 03-11-2003, 11:12 AM   #8
d240t2
d240t2 is an unknown quantity at this point
Send a message via AIM to d240t2
It isn't a myth. It happens. On some cars, it is worse than others. If it doesn't do it on your car, then you got lucky. There is a sound basis for why it happens, and there are also a ton of cars that had problems with it...so it isn't like it was just made up. My old black hatch used to have problems with it...that is why I went blow-through on my white hatch (I wanted to experiment...and was one of the first to do the blow through and share my findings).
Dennis
d240t2 is offline   Reply With Quote
Old 03-11-2003, 11:54 AM   #9
Foxcolt
Foxcolt's Avatar
Well, here was my situation.
I had an older blitz piston type. stayed open at idle. Just a tad. Had to heel toe everytime I came to a stop to keep it from stalling. Bought an hks diaphram type. Haven't had a problem since.
Civickilla has a piston type. Turboxs. keeps it closed at idle. No problems.
the reason why your car stalls is because of the fact that idle air is being let out of your bov. of it not shutting all the way when you come to a stop or let off the gas from highrpm's. wouldn't it be obvious that the solution would be to stop the leak?
Not trying to insult you. I just wanted to show you that I've had experience in both situations and to let everyone know that it's easily corrected.
Almost all bov's on the market are piston type, most of em you can't adjust to the point where it'll stay closed at idle it was impossible for me to do it with my older blitz. I'm pretty sure if we took a poll of who had what bov compared to who sufferes from the idle problem we'd start to see a corelation.
Driftec
Old 03-11-2003, 12:06 PM   #10
RedSuns
RedSuns's Avatar
good call Jed.....i will ask around and see what i can find out.....
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
Old 03-11-2003, 08:17 PM   #11
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jed. It's not an idle problem. The stumbling problem both Dennis and I are talking about is right after a shift.
When the MAF is used as a draw-through maf, it meters the air before going into the turbo. Then the air travels through the piping and intercooler, it has already been metered. Once an open-atmosphere bov lets the metered air out of the piping, bad **** happens. The ecu expects a certain ammount of air to come through once the throttle opens, but it's not there. The BOV let it out. So you have a ton of gas ready for that metered air, and no air. You run very rich, and it stumbles.
This is the sound basis for why the stumbling happens after the shift.
-Jeff
Whatup?
Old 03-11-2003, 09:49 PM   #12
Jsquared
Jsquared's Avatar
the vast majority of the time you won't be so rich too stumble, most people will just have a little "afterburner" thing going on when the extra gas hits a hot spot on the exhaust...
Old 03-11-2003, 09:57 PM   #13
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
to say "the vast majority of the time" really isn't correct, because anyone running a decent amount of boost (maybe over 7psi) WILL have a problem, because then we're talking about a LOT of metered air not actually seeing the combustion chamber, resulting in a LOT of fuel dumping into the chamber with no air to burn it.
AceInHole is offline   Reply With Quote
Old 03-11-2003, 10:18 PM   #14
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
How exactly does a recirculating BOV work? If it recirculates, how does it lessen the pressure and keep the turbo from stalling?
Learn everything you can, while you still have the chance.
transient is offline   Reply With Quote
Old 03-11-2003, 10:35 PM   #15
Jsquared
Jsquared's Avatar
do you consider 15psi "decent"? because we've been running that for 3 years and never had a stumbling problem.
Old 03-11-2003, 10:37 PM   #16
Jeff240sx
I hate you too...
Jeff240sx's Avatar
There are so many variables. What turbo do you run? Piping size? SMIC or FMIC? What BOV? Are you using a standalone EMS? Apexi AFC?
-Jeff
Whatup?
Old 03-11-2003, 10:43 PM   #17
Jsquared
Jsquared's Avatar
Porsche 944 turbo: stock turbo (K26), stock everything except: AutoThority MAFS (stock location, electronic instead of flap-type), K&N cone filter, AutoThority Stage III chipset, Magnecor spark plug wires, B&B Tri-Flo test pipe and cat-back, stock BPV/BOV vented to atmosphere, LindseyRacing "boost enhancer" (progressive valve on wastegate actuator line, basically keeps wastegate totally shut until 4,000rpm instead of it constantly creeping open like stock... solely for quicker spool-up and better low-end torque, overall boost level is controlled by ECU). the only variables that should matter in this case are the test-pipe+catback, increased boost from chipset, and BPV vented to atmosphere. oh yeah, piping size is about 3", and stock small FMIC.
Old 03-11-2003, 11:25 PM   #18
AceInHole
Autox Technician
AceInHole's Avatar
so, you're trying to compare a Porche to a Silvia or 240sx?
Old 03-12-2003, 12:07 AM   #19
Jsquared
Jsquared's Avatar
whether Porsche, Silvia, RX-7, whatever, the same thing happens. BOV vents to atmosphere, computer sees a lot more air than is actually getting into the pistons, injectors spray too much fuel, get split-second lean condition, sometimes ignites in exhaust stream. same thing with any turbo car with any vented-to-atmosphere BOV with any cat-less exhaust system. RX-7s, Supras, Eclipses, whatever. same mechanical events occur with the same components.
Old 03-12-2003, 12:15 AM   #20
Jeff240sx
I hate you too...
Jeff240sx's Avatar
I'm pretty sure that if you don't have problems, it's because the car came stock with the bov, and the fuel delivery is probably controlled by the ecu during the shift.
In the sr20det, I really don't think that they come with a bov, and have stumbling problems. The KA-T.. well.. you know. Not even supposed to be turbo'd.
Also.. cars like the z31 turbo had pop-off valves, which are more like safety mechanisms than turbo saving bovs are. Pop-off valves suck.
-Jeff
Whatup?
Old 03-12-2003, 12:41 AM   #21
Jsquared
Jsquared's Avatar
NO. the 944 turbo comes with a bypass valve stock, as does nearly every single turbo car made by anyone. the Silvia also comes stock with a bypass valve. a blowoff valve is just a bypass valve vented to atmosphere instead of rerouted back into the intake between the MAFS and turbo inlet. running a vented-to-atmosphere BOV on an S13 SR is no different than running the OEM BPV and venting it to atmosphere on a 944turbo (aka "951" in Porsche-speak) which is no different than a BOV venting to atmosphere on an Eclipse turbo which is no different than a BOV venting to atmosphere on an RX-7... get the drift? (no pun intended)
pop-off valves are completely different. a BPV/BOV prevents compressor surge to protect the turbo when the throttle closes under boost (as you know already)... a pop-off valve merely releases pressure when a car overboosts, mainly as a back-up for the wastegate in case the wastegate for some reason malfunctions and can't keep the boost down (which really doesn't make any sense because a wastegate is much more effective than a pop-off valve at regulating boost pressure). the only modern vehicle you should see a pop-off valve on is a CART Champ Car, and the governing body uses these to prevent teams from "turning up the knob" on the wastegate control and getting more boost, and thus more power, than other teams (the pop-offs are distributed by the governing body and are all set to the same psi).
Old 03-12-2003, 12:48 AM   #22
Jeff240sx
I hate you too...
Jeff240sx's Avatar
So now that we agree on the pop-off valve, and the bypass valve, and the difference in a bypass valve and a blow off valve, you mention that you have a bpv.
Is that why you don't stumble?
-Jeff
Whatup?
Old 03-12-2003, 08:19 AM   #23
Foxcolt
Foxcolt's Avatar
-Jeff
Your completly right, but as I asked in a post before. Is this a big enough problem to warrent the effort and money to go with a blow through setup?
Also what exactly is this "stumble" you guys are experiencing? When I shift at high rpm the worst that happens is my car shoots a flame. Never really had anything that I could equate to a stumble.
I've always heard people complain about stalling at idle due to mafs based cars w/ atmoshereic bov's but this is the first time I've heard of people having problems when they shift.
Driftec
Old 03-12-2003, 08:26 AM   #24
d240t2
Just because you have had 2 cars that didn't have problems, it doesn't mean you have solved the issue and that everyone else is making stuff up. 2 cars = 2 data points, which is not enough to pull a firm conclusion.
My car now, I run a blow through MAFS, so I don't have problems. My last car did have problems. Some do, some don't. It depends on a lot of factors.
If you want to tell people that they won't have problems with a certain setup, go ahead...but won't you feel bad when somebody does have problems because you made a conclusion too soon?
Dennis
Old 03-12-2003, 08:28 AM   #25
Foxcolt
Foxcolt's Avatar
I think what Jeff was trying to say is the reason you don't stumble or have any problems is due to the ECU.
All stock turbo euro cars be they crapwagons (Sorry! I hate em, no offense intended) or porshes are boost controlled from the ECU. Our cars whether they be ka-t or SR's the ECU has no idea there's a turbo in there. It only reads mafs voltage. In that sense i think it's safe to assume that your porshe ECU has sometype of algorithm to compansate for lost air during shifts.
Driftec
Old 03-12-2003, 08:35 AM   #26
Foxcolt
Foxcolt's Avatar
Dennis
hmmm... I see your point.
How would you reccomend I test this theory further? I firmly believe that the conclusions I've drawn are correct, and I'd like to have it stated as fact as opposed to theory but unfortunatly at this point I only have frequent access to one turbo car (mine) so I can't test my BOV on other people's cars. Maybe during the summer when the turbo 240's around my area get done I can find the one's that experience this mafs problem and see if putting my BOV on their car corrects it.
Driftec
Old 03-12-2003, 09:01 AM   #27
litlespic
litlespic is an unknown quantity at this point
Send a message via AIM to litlespic
I think a big reason that the 240's see a stumble with a BOV more htan the porshe is that the porshe most likely has a 1.1 afpr.. where as ace in the hole recomends a 10.1 which means A HELL OF A LOT MORE FUEL when the car is goin into a rich state...
And now I see why you'll hated me for comparing the 2.3 lima to a ka.. sorry guys
88 Merkur, just a little 2.3
litlespic is offline   Reply With Quote
Old 03-12-2003, 11:15 AM   #28
Jeff240sx
I hate you too...
Jeff240sx's Avatar
1) For you, no. For other people.. it depends on how bad it is. It was bad enough for Dennis to go with it. I'll let you know how mine is in a few weeks. Also, if you have the problem even the slightest bit, and are a drag racer (need to extract every ounce of speed), you'll want to switch to a blow-through setup.
2) From what I've heard about, its a flooding out problem, where the car makes no power just after the shift and hesitates. The fuel needs to be burnt off before power can be made.
3) Yea. The idle problem is the bov leaking at idle as you said before.
Oh yea. The s-afc has a setting for atmospheric bovs, and helps some.
-Jeff
Whatup?
Old 03-12-2003, 11:35 AM   #29
Foxcolt
Foxcolt's Avatar
ah I see.
that clears things up.
So in conclusion.
To stop stalling on idle, get a BOV that doesn't leak.
To stop hesitation on shifts get a recirculating BOV. Or convert to a blow through setup.
done
Driftec
Old 03-12-2003, 01:12 PM   #30
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
well, not done.. that sounds like lotsa work, and I planned on running an S-AFc or an F con.. I would be able to get around those problems with one of those computers, correct?
if the S-AFC solves them with its atospheric BOV setting than that just made up my mind when I finally swap.
andrave is offline   Reply With Quote
