Old 03-24-2009, 12:07 PM   #1
rocksteady_racer
rocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her self
Send a message via AIM to rocksteady_racer Send a message via Yahoo to rocksteady_racer
More 300ZX E-brake Woes
Ok I got a new handle installed from a 93 240sx since my stock one was so rusted there was no way to get the e-brake hooked up. So I put the new one in (same as stock) and the 300zx e-brake cables are too long. I've never heard of the 300zx e-brake lines to be too long on any 240 swap so this completely confuses me. Also the e-brake is adjusted all the way down. Any ideas? thanks in advance.
rocksteady_racer is offline   Reply With Quote
Old 03-24-2009, 12:13 PM   #2
toointoxicated62
toointoxicated62 is an unknown quantity at this point
what car is it in? a 240sx or 300zx you werent clear
toointoxicated62 is offline   Reply With Quote
Old 03-24-2009, 12:16 PM   #3
rocksteady_racer
O it's a 91 240sx with 90 300zx all around brake setup. and 300zx drum e-brake. That should clear that up.
Old 03-24-2009, 12:17 PM   #4
J.Silvia
J.Silvia's Avatar
J.Silvia is just really niceJ.Silvia is just really niceJ.Silvia is just really niceJ.Silvia is just really niceJ.Silvia is just really niceJ.Silvia is just really niceJ.Silvia is just really niceJ.Silvia is just really niceJ.Silvia is just really nice
are the cables from a 2 seater or a 2+2?
J.Silvia is offline   Reply With Quote
Old 03-24-2009, 12:19 PM   #5
rocksteady_racer
That I'm not sure of. Why are they different?
Old 03-24-2009, 12:58 PM   #6
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
original mounting points are different and 2+2 cables are a bit longer. Both work, but you need to work some things out.
For the 2+2 cables you need a secondary bracket to mount them a little further back. If you mount them in the stock location as the s13 cables they have to much slack.
For the 2 seater cables you need to reroute them through the subframe and have a bracket made as well.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 03-24-2009, 01:05 PM   #7
rocksteady_racer
Ah ok. Yea I used the stock mounting holes for the cables that's probably why there is so much slack. I routed then through the sub frame though like I assumed they were supposed to be. The bracket from the handle is fine just too much slack in the actual brake lines. There is no bracket stock so any pics anyone has of their setup I can compare too? I just bolted them up where the 240sx stock lines were. So if I mount the cable mounts farther back myself then they should have enough tension? Like can I just bolt the cables back a little farther with screws like stock or does a special bracket need to be fabricated? Thanks in advance for all your help.
Old 03-26-2009, 10:13 AM   #8
SILVIA_KIDs14.5
SILVIA_KIDs14.5's Avatar
Trader Rating: (-1)
SILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choices
Feedback Score: -1 reviews
so the 2+2 lines would be good for the s14 i take it?
SILVIA_KIDs14.5 is offline   Reply With Quote
Old 03-26-2009, 03:28 PM   #9
DreamN
DreamN's Avatar
Trader Rating: (54)
No, as mentioned in this thread already. R33 cables go with the S14.
Z32 cables (2 seater or 2+2) work with the S13.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 03-26-2009, 03:29 PM   #10
projectRDM
projectRDM's Avatar
No. R33 cables are a direct fit for S14s. Only R33s. The Z32s will work in both 2seat and 2+2 setups with S13s, but brackets are required per cable. TT cables have a larger end and won't fit with the S13 or S14 handle.
FORMERLY R240NA
Old 03-24-2009, 01:09 PM   #11
Brian
Brian's Avatar
Trader Rating: (54)
I suggest contacting a guy on here under the name "VESPAMAN"
I bought my bracket from him. Maybe he has some more.
That's all you need.
My situation was 100% the same as yours.
http://bhworld.wordpress.com/
Old 03-24-2009, 01:14 PM   #12
DreamN
DreamN's Avatar
Trader Rating: (54)
I'm sure many have just drilled a hole further back and used self tapping screws or whatever. I happen to use a simple diagram that Crimson Rocket had posted a while back for my bracket. Search for it, I'm sure you'll find it.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 03-24-2009, 01:31 PM   #13
rocksteady_racer
I tried looking for CrimsonRocket's Diagram but no luck. I guess I'll just see if I can drill them back a bit.
Old 03-24-2009, 01:42 PM   #14
DreamN
DreamN's Avatar
Trader Rating: (54)
http://zilvia.net/f/tech-talk/230394...e-bracket.html
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 03-25-2009, 03:55 PM   #15
Brian
Brian's Avatar
Trader Rating: (54)
I went with VESPAMAN'S bracket.
couldn't be happier.
Old 03-26-2009, 12:32 AM   #16
MyLevinGTZ
MyLevinGTZ has a spectacular aura aboutMyLevinGTZ has a spectacular aura aboutMyLevinGTZ has a spectacular aura aboutMyLevinGTZ has a spectacular aura aboutMyLevinGTZ has a spectacular aura aboutMyLevinGTZ has a spectacular aura about
That bracket listed in the link is mine. pretty cool to actually see it getting propogated out. lots of people need it.
i have it traced on a piece of paper and can make copies if anyone needs it. it's for a S13, i have R33 brakes. just shoot me a PM or email and i can get it sent out.
but you should be able to just print out that diagram and resize it until the printer makes it the size listed on the diagram. done and done.
MyLevinGTZ is offline   Reply With Quote
Old 03-26-2009, 03:15 PM   #17
Brian
Brian's Avatar
Trader Rating: (54)
There are at LEAST 2 different brackets mentioned in the link.
One is a drawing
One is a real bracket.
I didn't use either of them.
Old 03-26-2009, 03:30 PM   #18
DreamN
DreamN's Avatar
Trader Rating: (54)
One is a drawing
How much was VespaMan's bracket? $50 for the other one is quite high for something I could make myself. If VespaMan's is cost friendly then it'd save me a bit of time.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 03-26-2009, 05:33 PM   #19
MyLevinGTZ
One is a drawing
ah, the picture.
i wanted to make something that was easy to reproduce and free.
stupid to pay for something so simple.
Old 03-25-2009, 12:24 AM   #20
fueled by hate
fueled by hate is making a name for him/her selffueled by hate is making a name for him/her selffueled by hate is making a name for him/her self
I've heard multiple people say the r33gts e-brake cables fit perfectly. You can get them for $105.
MyNismo.com - R33 E-Brake Cables
fueled by hate is offline   Reply With Quote
Old 03-25-2009, 01:03 AM   #21
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
^^^^ what you "heard" is for S14's not S13's
Review Thread
bardabe is offline   Reply With Quote
Old 03-26-2009, 09:28 AM   #22
druthafoo
druthafoo's Avatar
druthafoo is an unknown quantity at this point
^I'd like a copy of that. I'm about to do my z32 swap either this weekend or the following week.
I'm trying to understand the trace tho. So the two slots in the top left and right are holes? and the four dots in the bottom are studs? or holes?
***PM for Stereo Help***
Eclipse55090CrystalSSCS6SIMAG
druthafoo is offline   Reply With Quote
Old 03-26-2009, 10:37 AM   #23
Enna
Enna will become famous soon enoughEnna will become famous soon enoughEnna will become famous soon enough
Send a message via AIM to Enna Send a message via MSN to Enna
Ugh....
here
Originally Posted by soreballz View Post
I hoped the candy would make it delicious, but I was incorrect.
Enna is offline   Reply With Quote
Old 03-26-2009, 03:33 PM   #24
Brian
Brian's Avatar
Trader Rating: (54)
It was not $50.
You would have to ask him about it.
I don't like to discuss prices that I pay for things.
His are very nice and I 100% suggest them
Old 03-26-2009, 03:36 PM   #25
DreamN
DreamN's Avatar
Trader Rating: (54)
Understandable. I'll PM him.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 03-26-2009, 03:37 PM   #26
Brian
Brian's Avatar
Trader Rating: (54)
Very good sir.
have a pleasant day.
Old 03-26-2009, 05:39 PM   #27
Brian
Brian's Avatar
Trader Rating: (54)
all sick. . .
