03-25-2009, 12:30 PM | #1 |
sr20det oil filter help????????
sup guys its me again. just did an oil change on my s13 sr20 blacktop for the first time and was wondering if the oil filter that i used is the right one. reason i ask is because the filter that was on there was much bigger than the new one i got from nissan over in duarte. the old one model number is: AY100-TY015 by Pit Work. new filter is: 15208-53J0A by Nissan. thanks guys
03-25-2009, 01:23 PM | #3 | |
Trader Rating: (18)
Feedback Score: 18 reviews
yes sir that is correct the P# is 15208-53J0A Dont forget to change your drain plug washer as well P# 11026-01M02 |
03-25-2009, 01:27 PM | #5 |
hey make sure u get the right one or else at high rpm it will pop the filter out and ur screw. Here is the right one for s13 blacktop n redtop that you could use from the se-r= 15208-53j00. This is for a fact because i have a s13 blacktop as well and i use some another model but from the se-r as well and it filter fell off on me. GL man.
ps- there are other filters from other cars that you can use as well though |
03-25-2009, 01:27 PM | #6 | |
Trader Rating: (18)
FYI !!!! 15208-53J00 superceeds to a 53J0A |
03-25-2009, 01:32 PM | #7 |
Trader Rating: (60)
Feedback Score: 60 reviews
Toyota part number 90915-YZZF1 works too. I have a 98 toyota corolla that uses that filter also. That way I can make just one trip to the toyota dealer and buy filters for both my toyota and my nissan. I have a s13 sr20det and have been using that filter for the past 4 or 5 oil changes. Also this filter is about an .5-1 inch longer so just a tad more oil capacity.
Also Toyota filters are made by Denso which are supposed to be one of the better filters out there. |
12-30-2011, 09:10 AM | #10 |
04-15-2009, 09:51 AM | #11 |
i use a K&N KA24DE filter. why cause its much bigger for my SR and it seems to work pretty well. oil seems much cleaner after using it
10-05-2012, 09:06 AM | #14 | |
WTF?? i thought S13 blacktop,and red top were both same size Filters Dont you mean S13 blacktop/redtop : 91 SER S14/S15 Blacktop : 95 SER. ? Shit like this confuses people
. Last edited by OutlawLui; 10-05-2012 at 09:31 PM.. |
12-31-2011, 01:55 PM | #20 |
Its not crap they did a video about oem filters that are made by honey well, Nissan and subaru are the worst ones. Even dodge has better oem filters than nissan
Obliterate |
04-20-2009, 12:36 AM | #21 |
The Nismo Shop : West Covina Nissan : Nissan OEM Oil Filters not that bad if you order a few
10-10-2009, 10:25 AM | #22 |
10-10-2009, 11:06 AM | #24 |
Explain how an oil filter can produce better oil pressure.
01-01-2012, 12:34 PM | #25 |
I'm very surprised nobody said anything about the purolator pure one sooner. Fail. Teflon infused poly oring and drainback valve win.
The two constraints that hold engineers to filters are mainly maximum flow and minimum particle size. When creating a filter to handle .01 micron particles, it's hard to allow a lot of fluid flow to pass through per unit time. With a greater more free flowing filter element, pressure DROP across the filter paper is decreased, which increases your effective oil pressure at its destination.
12-02-2011, 08:58 AM | #28 |
Talking bout back from the dead. See, i searched!!!
Why do people say redtops use 91ser filters but blacktops use 95ser filters? Dont both engines have identical oiling systems? Why cant you use one filter on both? 2. If running a relocation kir, can one use the largest filter that threads on and seals regardless of make, model? Ie: arent all filters the same thing, just made in different sizes? |
12-02-2011, 10:28 AM | #29 |
It won't screw on because they are different sizes.
Yes you can run a huge filter if you want. If you are running something gargantuan I suggest priming your oil system after oil changes before starting the car.
12-03-2011, 11:40 AM | #30 |
Thanks!!!! So to clarify, filters dont have different pressure relief valves, or resistance to them? Just different sizes, right?
Why doesnt everyone stop running these tiny ass filters then? Its not like the sr20 carries a lot of oil as is.....it needs every additional drop you can fit |
