Old 04-16-2009, 03:38 AM   #1
Este510
Este510 will become famous soon enoughEste510 will become famous soon enoughEste510 will become famous soon enoughEste510 will become famous soon enoughEste510 will become famous soon enough
SR will not start after it warms up
The car will not start when it's warm, however if I disconnect the coolant temp sensor it fires right up. I've already change the sensor twice. When the CTS is hooked up it runs fine for a while then it starts bucking and back firing, but as soon as I disconnect it runs perfect. What could it be?
Este510 is offline   Reply With Quote
Old 04-19-2009, 03:08 PM   #2
Este510
Anyone????
Old 04-19-2009, 03:17 PM   #3
cotbu
cotbu's Avatar
Uhhh ummm the CTS! check ecu for codes. then check the wiring for coolant temp sensor then see what your coolant temperature is. Make your engine run cooler?
Old 04-19-2009, 03:26 PM   #4
greenman100
Trader Rating: (18)
greenman100 is an unknown quantity at this point
Feedback Score: 18 reviews
you're changing the wrong sensor
greenman100 is offline   Reply With Quote
Old 04-22-2009, 10:36 AM   #5
Este510
I know where the sensor is, I changed it twice, and I have a power fc so I can't check for codes any other advise?
Old 04-22-2009, 11:01 AM   #6
DC29
DC29's Avatar
DC29 is an unknown quantity at this point
hmm. possibilities.. heres what sounds like is going on, when your car is running after you first fire it up aand its cold the ecu throws more fuel in the motor until it warms up to normal operating temp. so what it sounds like is it thinks its cold the whole time even after warm up and is over-fueling.
1. too much resistance in wire to/from CTS
2. could be the sensor
3. bad ecu
4. thermostat
i would check your thermostat first
DC29 is offline   Reply With Quote
Old 04-23-2009, 03:53 AM   #7
Este510
I replaced the thermostat about 9 months ago, I will look at it again tomorrow, THANKS!
