Old 04-18-2009, 06:55 PM   #1
180ways2slide
180ways2slide's Avatar
180ways2slide is making his/her stupidity well-known180ways2slide is making his/her stupidity well-known180ways2slide is making his/her stupidity well-known
warped or not
my buddy has an det with a power enterprise metal headgasket. he removed the head to put on a built head but the sale fell threw. now when he puts back on the metal hg he uses copper spray bu.t torques the head down in wrong order.did he damage the head or can he just loosen everything and re torque the head..
also he never had an over heating problem or any thing, the head was just taken off because he thought he was getting a built head. i told him to loosen it and re torque i wasnt sure if the head could get warped like that.. thanks
180ways2slide is offline   Reply With Quote
Old 04-19-2009, 02:41 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I dont know about it getting warped because its not torqued properly, I'd be more worried about it leaking.
CLICK HERE!!!
Old 04-19-2009, 03:07 AM   #3
GSXRJJordan
GSXRJJordan's Avatar
Only one way to find out lol.
Pull the head off, reseat, retorque (in order), and run that bitch.
Old 04-20-2009, 01:34 AM   #4
dOMEmE
dOMEmE's Avatar
dOMEmE is an unknown quantity at this point
yup.......only way to find out for sure indeed.
dOMEmE is offline   Reply With Quote
Old 04-20-2009, 05:34 PM   #5
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
pull it off and lay a straight edge down and measure... do a google search on how to check a head for warpage, and you buddy is an idiot, let him know that 10 times
handinpants is offline   Reply With Quote
Old 04-20-2009, 07:26 PM   #6
moses
moses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-known
I might have some bad news. I was one of the idiots that torqued on the head bolts backwords. I just loosened them up and torqued them down. I drove on them for about 250 miles then went to go get it dynoed. I ran it hard on a dyno with no problems but when I ran against a vette later that night I suddenly lost compression in all 4 cylinders. It looked like I was getting bad detonation but I was not able to open it and look into it because I got deployed to Iraq. It was weird because there was no leaks anywhere so i dont really have a clue what it was.
If there is a way to check for head warpage I would do it.
Thats what I said
moses is offline   Reply With Quote
Old 04-20-2009, 08:10 PM   #7
fliprayzin240sx
Compression check before anything else...
CLICK HERE!!!
Old 04-20-2009, 08:35 PM   #8
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
Yea you can check with a straight edge or one of them fancy rulers (dont know the proper name) place the head on a flat surface you should be able to tell if its uneven or warped. Or if your not 100% sure take it to a shop have them check. And another thing there is a torque sequence. When torquing the head you start from the inside out and also when removing the head it has its sequence from out to in. So if you just loosen the bolts with out using the sequence you my friend F'd up. It's all in the FSM
zylvia213 is offline   Reply With Quote
