Old 04-19-2009, 12:48 AM   #1
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
HELP! ECU Code 43! WHAT THE FUDGE!!!
Howdy folks. Thanks in advanced for taking a gander at my thread. Onto the details!
1990 SOHC KA
Auto to 5 Speed swap
SR Tranny
Reverse sensor not plugged
Previous, the car was an automatic. A while back, we converted it into a 5 speed, using all the right parts. I was still using an AUTO ecu, with an AUTO TPS. I have dealt with all the codes I had previously thrown, but am now left with one - ECU Code 43, throttle position sensor. I have tried replacing the TPS with a BRAND NEW Manual TPS, but I still got the TPS code.
I recently have received a manual ECU (confirmed with JWT's ECU guide) to replace my AUTO ecu. I am still getting code 43.
Does having an AUTO TPS set off the CEL code? Is there anyway to bypass the TPS code, or do I have to try another manual TPS?
I do know that I SHOULD use a manual TPS, but frankly, money is tight.
The main reason for getting on this problem now is the fact I have an appointment with state ref because of my intake. Go figure.
ANY help will be greatly appreciated. Russ, almight 240sx God, it'd be awesome if you chimed in as well.
PS. Someone let me borrow a stock SOHC exhaust.
SochBAT is offline   Reply With Quote
Old 04-19-2009, 12:59 AM   #2
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Don't know how much a difference it is from SOHC to DOHC, but you could try using the same inspection procedure provided in the FSM for 91-94 240SX; Section EF & EC - Procedure 33 Page 121.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 04-20-2009, 03:43 AM   #3
idlafie
idlafie's Avatar
1990 SOHC KA
SR Tranny
Get a volt/ohm meter & check for continuity and voltage between the ECU and the Throttle Position Sensor connector. Maybe you have a short in the wiring harness or ground somewhere for the TPS circuit. Looks like you're gonna have to pull out the wiring diagram from the Factory Service Manual to trace this problem down.
Hope this helps......Good luck!!!
ID
Old 04-20-2009, 02:21 PM   #4
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
You dont just install a tps sensor, you have to calibrate it using a multimeter.
My shoe is undesired
undesiredshoe is offline   Reply With Quote
