Ka24de won't idle
Car cranks then will stumble and die out, unless I rev it and after 3000 rpm or so it smoothes out. If I disconnect the maf it idles fine. I have replaced the maf, and that it not the problem unless I have two bad mafs. I tried the ever elusive search button and have found a few threads pertaining to the IACV. I believe my next step is to verify the timing and clean the IACV, possibly run some Seafoam. Other than that I am out of ideas. Anyone have other suggestions?
Today I replaced ECU, Removed and cleaned IACV, seafoamed the engine from the brake booster vacuum. Nothing has changed, engine still stumbles, shakes and will barely run, runs good above 3500 rpm though.
I checked for vacuum leaks with carb cleaner and believe I have found something. When I spray the cleaner on the injectors/O-rings, I get a drop in idle. I am guessing the o-rings are bad, or not properly seated. What is a good method to reinstall the injectors and ensure they are seated and not leaking vacuum? |
It is the Idle Air Control Valve. Its it located on the passenger side, on the backside of the engine. Your brake booster vacuum hose should be plugged into it. To clean it you can either remove it and dissemble and clean it. Or you can spray manifold cleaner into where the vacuum hose connects. It is a little tricky to keep the car running, have to do it quickly, and has to manifold cleaner. I have heard other cleaners such as carb cleaner and brake cleaner could damage it.
