Old 05-21-2009, 08:20 PM   #1
dsmdeliveryboy
dsmdeliveryboy is an unknown quantity at this point
Megan Racing springs installed, ran into slight problem.
Ok so I just got done installing my Megan Racing springs and they went on without any problems, once I got the back on I noticed that when I push the back end down and compress the struts they act they're loose but they're completely tight... They are the stock struts but they're almost new(no money to buy aftermarket struts right now )and the front end isn't doing it so I'm kind of lost...
dsmdeliveryboy is offline   Reply With Quote
Old 05-21-2009, 08:28 PM   #2
LongGrain
LongGrain's Avatar
did you put the little rubber bump stops back on the shocks when you were reassembling them? i forgot that when i first did mine and i had the same problem.
LongGrain is offline   Reply With Quote
Old 05-21-2009, 08:32 PM   #3
dsmdeliveryboy
Ya I made sure I did that, I'm completely lost because as far as I know they're put together right. I took the strut and put the spring in it and compressed the spring and put the top hat on and then the washer and nut...
Old 05-21-2009, 08:43 PM   #4
s13boy89
s13boy89's Avatar
s13boy89 is on a distinguished road
Send a message via AIM to s13boy89
the rear is going to be softer because in the front you have a motor
I have kids running around here I dont want to use an xxr as a coffe table
s13boy89 is offline   Reply With Quote
Old 05-21-2009, 11:49 PM   #5
all stock
all stock is on the path to ruinall stock is on the path to ruin
how "new" are these struts? if they're OEM, they're bound to be around 10+ years old, unless someone bought OEM ones from the dealer.
NASA PTD/SCCA ITS
all stock is offline   Reply With Quote
Old 05-22-2009, 12:51 AM   #6
dsmdeliveryboy
They're less than a year old and half of the year the car wasn't even on the ground
Old 05-22-2009, 06:59 AM   #7
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
I have Megan springs on Ohlin's struts and I don't have any problems, I have them on a set of KYB struts before and no problems with them either.
HYPNOTIK is offline   Reply With Quote
Old 05-22-2009, 11:48 AM   #8
dsmdeliveryboy
I just dont get why its doing that, I think I'm gonna pull em off tomorrow and check em out.
Old 05-22-2009, 12:14 PM   #9
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
did u check the shocks/struts for play when they were out even though they are a year old they can still blow. take them out and push them in and out if its easy then they are blown if they are tough then they should be good
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 05-22-2009, 09:25 PM   #10
dsmdeliveryboy
Well I took a little closer look today and it looks like the struts are too long for the springs, the threads for the struts are way too long and stick up a lot so it just seems like I'm riding on springs when I drive around. And I went and bought one new strut because it wasn't rebounding like you said and still nothing... Can someone show me a diagram or something of everything? I've lowered a lot of different cars I've owned and I've never had this problem...
Old 05-22-2009, 09:50 PM   #11
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
sell everything you have and buy some used megans?
repda916 is offline   Reply With Quote
Old 05-22-2009, 11:07 PM   #12
dsmdeliveryboy
wouldn't add up to enough and I'm already trying to deal with other more serious problems the car is having.
Old 05-23-2009, 11:45 PM   #13
dsmdeliveryboy
Need some help, need to get this car on the road. Will buy beer for someones help.
Old 05-30-2009, 12:31 AM   #14
ImPLiCiTS14
ImPLiCiTS14 is an unknown quantity at this point
Send a message via AIM to ImPLiCiTS14
im also having same issues installing eibach sport lines on tockico struts. Anyone?
ImPLiCiTS14 is offline   Reply With Quote
Old 05-30-2009, 10:41 AM   #15
dsmdeliveryboy
Uh threadjack???
