Old 06-10-2009, 09:23 PM   #1
nasx
nasx is making a name for him/her selfnasx is making a name for him/her self
S15 Silvia with a bad rattle
I just took delivery of a black 2000 S15 Qs (SR20DE) with full oem aero kit.
Darn it is a sweet looking car. Never saw one in person before.
But it has issues.
When cold it rattles VERY loudly at startup then the rattling all but goes away. When operating temp is reached, the rattling returns intermittently but not as loud as at startup. When revved, the noises seem to diminish unlike spun bearings that get louder when revved.
The stock oil pressure gauge is all over the place (jumpy needle movements and all) reading from normal at startup to zero when warmed up en then back up again, so I'm not sure it's working correctly.
My guess is thus the timing chain and/or tensioner, do the symptoms sound like the timing chain and/or tensioner to you, or should I still be thinking bearings?
If it's the tensioner, can the tensioner be changed without pulling the motor?
What about oil pump replacement can it also be done without pulling the motor? Thinking I might want to replace it just to be safe.
nasx is offline   Reply With Quote
Old 06-10-2009, 09:54 PM   #2
MannylovesLian
Banned from the Marketplace
MannylovesLian is an unknown quantity at this point
the noise is a bad intake cam gear!
You need to buy a new one.
I had the same problem.
MannylovesLian is offline   Reply With Quote
Old 06-10-2009, 10:02 PM   #3
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
you couldn't possibly state that as a fact. It's only a possibility. My guess is that is that it's a spun bearing or a bearing that's about to spin. If i were you I would check your oil pan for dents. if dents are found then replace. if rattling still occurs then check your rod bearings. As rod bearing wear you will see a decrease in oil pressure as more oil is slipping by the bearing. More than likely I would suspect rod bearings. It can also be piston slap....due to tapering of the cylinder walls. get it checked out. pull the valve cover off first and see if everything looks ok up top first.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 06-10-2009, 10:18 PM   #4
nasx
How can I test or inspect this? Is this a common/known problem with S15's
No dents on the oil pan it's in great shape. I will pull the VC over the wekend. The car only has 45k miles and otherwise mint. Seems like the previous owner took good car of the car, so i'm hoping it's not the rods.
Originally Posted by WoolyS14DET View Post
Take a vid and post on youtube and insert the link and let us listen
Will do that tomorrow
Old 06-10-2009, 10:08 PM   #5
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
WoolyS14DET is offline   Reply With Quote
Old 06-10-2009, 10:24 PM   #6
SoguRacing
SoguRacing's Avatar
also check for timing chain slack. it could be hitting the guide up top.
Old 06-10-2009, 10:29 PM   #7
Smurf_240SX
Smurf_240SX's Avatar
Smurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choices
Send a message via AIM to Smurf_240SX
Happend to my SR also turns out it was my Alternator Pulley bearing seized up. Noise would come and go. So that could be a possibility. Dont know about the jumpy oil pressure needle tho you might wanna check whats up with that first.
Smurf_240SX is offline   Reply With Quote
Old 06-10-2009, 10:32 PM   #8
nasx
Definitely not the pulley. but I'll try to get a mechanical oil pressure gauge hooked up to check the oil pressure.
This suck I only have the car less than 24hrs
Old 06-10-2009, 10:32 PM   #9
SoguRacing
SoguRacing's Avatar
perhaps the oil pick-up/sump is loose.
Old 06-10-2009, 10:36 PM   #10
Tensor187x
Tensor187x has a little shameless behavior in the past
I'm gonna go with dents in the oil pan.
Starving that engine of oil.
Tensor187x is offline   Reply With Quote
Old 06-10-2009, 10:40 PM   #11
nasx
Like I said above the oil pan is flawless. Thanks
Old 06-10-2009, 10:39 PM   #12
jackal264
jackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud of
rofl spun bearings...
here are my 2 guesses. i'm leaning towards #2
you said your having oil pressure problems, your just getting air in the lifters and thats causing the rattle until the motor gets oil through the head.
secondly like s14 sr20's you have vvt. the vvt units tend to make noise when they get old. the unit engages at 1000 rpm. so once warm your idle will fall back to 850 and you will not hear it but every time you rev you should hear a click at the throttle body then the knock. you can also try inpluging the vvt. thats the easiest way to eliminate it as the issue.
my vvt makes noise from 1000-1300 rpm and at idle it is quite loud but it works just fine.
edit: intake cam gear as mentioned above is the same thing i am talking about b/c on an vvt motor the cam gear is the vvt unit. so like the very first post says replace it to et rid of the noise.
jackal264 is offline   Reply With Quote
Old 06-10-2009, 10:43 PM   #13
nasx
Last edited by nasx; 06-11-2009 at 08:48 AM.. Reason: re-read post already got the answer
Old 06-10-2009, 10:49 PM   #14
nasx
Last edited by nasx; 06-11-2009 at 08:35 AM.. Reason: reread post already got the answer
Old 06-11-2009, 10:10 AM   #15
MannylovesLian
Trust me man. it is the VCT gear/intake cam gear. i had the very same problem, knock on warm up, oil pressure flux, come and go once warm.
I took apart my whole block and replaced everything! EVERYTHING but that intake cam gear. i thought it was an oil pick up problem or oil starvation whatever. but then my mechanic told me to change the intake cam because that was all that was left to change. Well What Do You Know! That Was IT.
you can buy a used one for cheap, but you wont know if that one is bad. just buy a new one to save you the hassle. or you can just delete it and buy cam gears, but that would defeat the purpose of the gear and you will just have a S13 motor.
Old 06-11-2009, 06:40 PM   #16
nasx
Tried getting a video of the rattling, but it all went away for several cold starts just light rattling once warmed up. Then when I did not have the camera it rattle like an angry diesel truck. A few cold starts later nothing again. removing the solenoid plug does not seem to do anything about the light rattling (sounds like a playing card running over bicycle spokes) once warmed up.
I'm looking into getting a cam gear? How much does a new one cost?
Old 06-11-2009, 10:32 PM   #17
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Either the VVT gear is fucked or the chain is tapping the retainer on top.
CLICK HERE!!!
Old 07-04-2009, 07:28 AM   #18
nasx
finally the video
YouTube - rattle sr20de
http://www.youtube.com/watch?v=1yIuSkvNpdg
Old 07-19-2009, 06:45 PM   #19
nasx
Replaced the cam gear, with a used low mileage one, (fingers crossed) and cleaned the tensioner with carb cleaner and WD40.
Rattle gone. I'm happy Thanks guys.
