![]() Join Date: Mar 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
Exhaust questions
I'm looking into getting an 89ish 240sx in august, and I plan to sooner or later get the SR for it, but until then I want to be able to get intake and exhaust, just because thats pretty much all i'll be able to afford after the car. What exhausts do you guys recommend that I could use on the stock engine and keep for the SR? Any photos would be helpful as well
Junkie
![]() Join Date: May 2002
You won't be able to use your intake once you get your SR. If anything get an exhaust. There are a lot of exhausts you could get for the SR but it depends on what you prefer as far as look or the sound of the exhaust.
-Juan |
let me know what you think of this.. I have a 93 240SX and was looking at some aftermarket exhaust setups. Theyre expensive. SO I went to a shop and had them cut the cat off, and replace the pipe from the downpipe to the (stock) muffler with hand bent piping that was a half inch bigger than stock. This cost me 90 bucks (Canadian) which is like 5 bucks American. Anyhow, It really improved top end pull a lot, and only reduced low end a bit, hardly noticeable. I kept the stock muffler for backpressure, I was told by the mechanic who did it that larger bore pipe tends to increase the power at higher RPMs, and if I didnt have the stock muffler for some restriction it would have likely shifted the power curve up higher than I could have used it. Sounded...unique, pretty good. I have since put the cat back on and noticed little change at all other than its quieter. I personally wouldnt put intake on it. I find theyre useless other than if you want that sound, then you can take the baffling off and it does the same thing. I told K&N I would buy a filter from t hem if they stopped advertising a 15 % increase in power! Good luck to you.
#6 | |
![]() Join Date: Dec 2002
Original poster, if you want a good all round exhaust for the KA AND the SR20 look at the N1 dual CAT-back. Good exhaust that sounds good, looks good, and good durability. Check out www.enjukuracing.com for a good price, those guys are really great over there.
Don't mess with my monkey...he's loaded. |
#8 | |
Proper exhaust design isn't about "backpressure" except trying to eliminate it entirely, while maintaining flow velocity. This means a properly sized pipe (which it sounds like you had) but as little restriction as possible (bad idea keeping the stock muffler). A more effective cheap upgrade would be to leave the stock tubing and change the muffler. You'd see small gains all across the curve. |
