![]() what type of lsd do you guys suggest that i get for my 96 se. does it matter if i have an auto tranny?
nothing breaks in new tires like kicking your back end out. |
![]() Join Date: May 2002
Decide what you use the car for most (street, drag, autocross, track, drift). Decide on a budget.
Then SEARCH... the merits of different limited slip types have been discussed here many times. It doesn't matter that you have an automatic, the diffs are all the same. |
street racing and drifting. does anyone make aftermarket vlsd. i dont want one that is to agressive and hard to maintain.
#4 | |
haha you pay for quality. you want agressive? VLSD IS NOT THE LSD!! VLSD sucks donkey dong. vlsd blows, espeically for drifting!! aggressive? VLSD is as agressive as a snail. get 2 way clutch lsd req. oil change every 3K (cost 40 bucks each time for fluids) rebuild after a few yeras or heavy use noisy and kills tires you want to be serious at drifting? you go balls out. imho. |
i go out drifting and when ever i get a chance but i still have to get to work in the morning. i was thinking id get nismo , direct install , and ive only heard good things about it.
#6 | |
ok then you are contradicting yourself nismo is: noisy kills tires very aggressive requires FREQUENT oil change (every 3k) it is a clutch 2 way LSD also direct install is used LIGHTLY. it is NOT direct install. you need 2 new output shafts (135 EACH) or get the nismo kit (900+ dollars) you still need to shim and such to spec, and if you dont know how to do it (as one past board member did-used open diff shafts) you destroy the LSD. professional install is HIGHLY suggested. it is not VLSD. it is not friendly. |
![]() Join Date: Feb 2003
Isn't the r200 LSD from quaife a good option?? It is the most expensive but no need to rebuild ever or break it in. Lifetime warranty on it as well. And it's not as harsh as a 2-way clutch lsd. It sounds like just what your looking for but you're gonna pay alot up front. retails at like 1250$!! That's what I'm going with in my '97 and I've heard you don't need new flanges or anything to install it as long as you have an open diff to begin with.
And I second the notion on the VLSD sucking balls, it does. |
#8 | |
its how it transfers power for drag or grip, QUAIFE rocks. go for it. but drift..no no. you want equal power to both wheels CONSTANTLY. |
![]() Join Date: Jun 2002
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
i say, just start out with a VLSD first and if u like it then upgrade. thats what im doing. of coure ull be spending a lot more money but hey, if u dont like drifting then u just didnt waste a lot of money on a Nismo. but wth am i talkin about..u wanna do drifting and street racing [thumbs down], Note that i DO NOT have my VLSD installed yet, and im contempting whether i should already sell it and buy a Nismo SSS already. but i know nothing about drifting and if i go straight to SSS im afraid to mess it up. i can take out all my mistakes on the VLSD. even with its snail like engagement
but like dousan said..if ur serious go all out. i know dousan showed me the light. im gonna go all out. and get a nismo SSS, yes i will give up the comfortible of daily driving. but its an opportunity cost. one or the other. nice ride or killer on the track? and i decided to go with the track. and bare with the roughness on daily driving. can u change the oil while the LSD is ON the car already? Last edited by SilviaDriver; 04-11-2003 at 12:19 PM.. |
![]() Join Date: Dec 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
wait wait wait... you go out drifting?
i thought you had a 96 open diff automatic? does this mean my car can drift too? o.O this is news to me~
#12 | ||
![]() ![]() oil changing, yes you can do it when LSD is on car. its easy, just need a breaker bar and some eblow grease and paitience. pump too is easiest!!! ![]() Quote:
#13 | |
#14 | |
![]() Join Date: Sep 2002
Keeping it Godzira bishes. So I murdered another turbo |
#16 | |
![]() Basically, you cannot get an LSD that is both aggressive and easy to maintain, unless you have craploads of money to buy a helical- (such as quaife) which still requires relatively frequent (though not as frequent as clutch type) fluid changes. Expect to pay over $1000 for the unit itslef! Drift - you want 2 way clutch type. Road Race (track) - Helical or clutch type 1.5 way Daily driven slightly harder than most - VLSD Granny where there's no snow/rain - open diff Drag - 1way clutch type.
Instagram: @SX180HKG |
#17 | |
thats a HUUUUUGE snail! granny, damn no wonder it too me so long to upgrade. southern california..no snow to battle, tad bit of rain to worry about...all these are symtoms of OSD syndrome. |
#19 |
Where can someone in SoCal buy a Nismo SSS? How is the maintenance on one? I am serious, if I make one investment, I might as well go for it.
[sits back and prepares for the flames] Last edited by masta; 04-11-2003 at 10:49 PM.. |
#20 |
when you say mechanical, I assume you mean helical... is that right? gear-type LSD is helical. Clutch type is... wel, clutch type. Nismo SSS is 1.5-way and 2-way adjustable (choose your way! ) clutch type, not helical.
I think helical LSDs are by definition 1.5 way, although someone may have to clarify that for me/you.
#21 | |
its special order from Nismo Japan! |
#22 | |
#23 |
YES it is VERY useful and makes it quieter too!
![]() my friend uses MOPAR works great too (and cheaper? not sure) the best way is to order a case. some friends and i are doing that...we use it so much and all have LSDs so might as well have it at once so when you get that late night urge to work on the car or change fluids, you can do it ![]() i use 90w140 because lots of track use. 3 events in 3 weeks and heavy abuse on the car..good piece of mind! and no problems at all, feels great and runs well. |
#25 | |
#26 |
Probably 80% of LSD people are happy running 75w-90 or 80w-120 (?). 90w-140 is a little heavy, and fewer people run it for whatever reason (not sure). That is to say, if you can't find 90w-140, don't worry about it.
#27 | |
#28 |
yeah i use 90w140 because i drift often. also Mike (VRT) suggested it to me when i was asking him what would be best for heavy track use. he uses it on his nismo 2 way and no complaints.
its nice to have that extra protection. just this friday (coming) at the track so 20 mins non stop drifting (6 times in the day i hope) on the track its a good piece of mind ![]() |
#29 |
WOW addicted
![]() Join Date: Dec 2001
Another option is the S15 Helical LSD.. they go on ebay for about $150 all the time.. ($120 shipping though)
things to make it work: 1. S15 Output shafts 2. Custom spacers so that you don't have slack b/w the 12mm ring gear bolts and the lsd's 13 mm bolt holes.
