Yes, I look like that
![]() Join Date: Mar 2002
Voltage regulation is only needed on the generator/alternator circuit, but alternators don't need voltage regulation, you regulate the output by regulating the input to it, and NONE of you has ownbed a car with a generator... If you are having a problem, it is likely something else. What exactly is happening?
![]() Join Date: Jun 2001
well if i didnt drive the car after like 2 days of not driving the car the battery would die..... then i changed the battery like over 2 years ago, and the same problem 2 days without driving the car dead battery and the new batter didnt help...... alternator?
Alternator, but you are in luck... The only thing that usually goes wrong in the alternator are the brushes, and this sounds like the problem you are having... Alt: Never bought one... Brushes: 10 bucks. You will have to disassemble to alternator to replace them if our alternators are like they were on my old cars, but I have never had to replace the brushes in my 240...
No, they are really simple to disassemble, just a coupla bolts holding it together on the outside and 3 on the inside to take out... The brushes are held in by small bolts and use springs to press them against the sliprings, once you have them in you are set, you will need to use a paperclip or a piece of safety wire to hold the brushes back while you put the rotor back in, then just pull it out once you are back together and the alternator wil be as good as new...
