Old 08-12-2009, 12:47 PM   #1
JoHn E
JoHn E's Avatar
JoHn E is an unknown quantity at this point
coilover preload changed on its own?
recently my front left coilover has been clunking when i turn, so i put the car up on a jack to look at it. i noticed that the front left coilover spring has a lot more preload than the front right. less than a year ago im SURE that the preloads were even on both sides. on the front left i can fit 3 fingertips in the area where u can touch the thread of the coilover. on the front right i can only fit 2 fingertips
has this happened to anyone else that has owned coilovers?
heres a picture. the section i highlighted in red is where im talking about how many fingers i can fit in
heyyy
JoHn E is offline   Reply With Quote
Old 08-12-2009, 12:53 PM   #2
BlitzRPS13
BlitzRPS13's Avatar
BlitzRPS13 has a little shameless behavior in the past
I think my front left has done this too.. not nearly as much.. but enough to make the spring slightly loose.. how it happened i have no idea.
BlitzRPS13 is offline   Reply With Quote
Old 08-12-2009, 03:02 PM   #3
JoHn E
JoHn E's Avatar
what did u do to fix it
heyyy
Old 08-12-2009, 03:36 PM   #4
BlitzRPS13
BlitzRPS13's Avatar
Nothing.. the car usually fixes itself.
lol no.. i haven't touched it yet.. been occupied on too many other things on the car.
Old 08-12-2009, 03:18 PM   #5
jamg
jamg is an unknown quantity at this point
is the clunking from when you turn your steering wheel?
jamg is offline   Reply With Quote
Old 08-12-2009, 03:23 PM   #6
JoHn E
JoHn E's Avatar
yea its only when i turn the steering wheel, the sound for sure is coming from the coilover
heyyy
Old 08-12-2009, 03:24 PM   #7
jamg
damn, guess i better go tighten mine then.
i get the same thing when i turn my steering wheel.
just make sure the locks fit snug under the coil. use some man muscle and make it tight. and lock it tight
Old 08-12-2009, 03:31 PM   #8
Wabash9000
Wabash9000 has a little shameless behavior in the past
spl parts has a special thrust bearing that should solve that problem. it allows the spring to freely rotate separate of the adjuster to that it doesn't have this issue. you have to take apart the entire coilover to install but it could be worth it.
at the bottom of this page.
http://splparts.com/main4/parts/S14/...rs/default.htm
Wabash9000 is offline   Reply With Quote
Old 08-12-2009, 04:29 PM   #9
Forge_55b
Forge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enough
somethings not tight enough so every time you turn it loosens and increases the height of the shock
Forge_55b is offline   Reply With Quote
Old 08-12-2009, 05:00 PM   #10
Sileighty_85
Sileighty_85's Avatar
I think the pillow ball joint is seized
http://zilvia.net/f/tech-talk/140603...ber-plate.html
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-12-2009, 06:54 PM   #11
Ali 556
Ali 556 is a well-known jackass
+1 Me too..STANCE have the rep of doing this...
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 08-13-2009, 01:10 PM   #12
JoHn E
JoHn E's Avatar
would a bad camber plate happen to cause this to happen to one side and not the other? I bought the coilovers as a set of 4 so they must have came from the same batch if it is the camber plate issue
heyyy
Old 08-13-2009, 01:24 PM   #13
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
either way.
if your gtting clunking ass spring sounds from your coils when you turn email stance.
telll them this is happening, they will gladly send you replacement pillowball things.
for free.
do it.
nieko is offline   Reply With Quote
