Old 08-15-2009, 10:49 AM   #1
David48
David48's Avatar
David48 is an unknown quantity at this point
Send a message via AIM to David48
Q45 5lug swap
O.k. this is a noob question, and I searched through a few pages, so please don't flame. I know it's more commonly done and easier to use S14 hubs for a 5 lug swap, but I have 2 junk Q45s just laying around, and one's gonna end up going to a junkyard once I complete the other. I've read about a lot of people using Q45 brakes, but no hubs. Is it possible?
David48 is offline   Reply With Quote
Old 08-15-2009, 11:35 AM   #2
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
No you cant use it.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 08-15-2009, 03:44 PM   #3
blackrms13
blackrms13's Avatar
^ um...yes u can
IIRC u gotta press in the s13/14 bearing in or something
not too positive on that
but there is a write up
search for it!
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 08-15-2009, 04:25 PM   #4
Charlie
Charlie is on the path to ruinCharlie is on the path to ruin
Originally Posted by blackrms13 View Post
^ um...yes u can
search for it!
I think you mean pressing S13/14 bearings in J30 hubs. IIRC you can use the whole rear J30 or Q45 rear knuckle in the back of S13/14's. Which means you can use the brakes/ebrake, 5lug, etc.
Charlie is offline   Reply With Quote
Old 08-15-2009, 05:03 PM   #5
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
u are correct
it was j30 front hubs.
Old 08-15-2009, 10:04 PM   #6
projectRDM
projectRDM's Avatar
Yes, however:
The Q45 rear upright is the same as a Z32, aluminum, but with a fork style mount rear shock. You'll need Z32 rear shocks.
Also, most Q45s were equipped with HICAS so you'll have to press the ball joint out where the toe rod mounts and press a bushing back in place.
Lastly, the rear hub is the same as a Z32 TT, so you can use it but you must use the axles as well, as they're a larger spline. This will require using the diff too since the axles are 5bolt.
The J30 rear upright is a direct replacement with no alterations or other parts required. The brakes are the same, but that's it.
FORMERLY R240NA
Old 08-16-2009, 05:50 PM   #7
blackrms13
blackrms13's Avatar
i apologize, got them 2 mixed up
