Old 08-15-2009, 10:26 PM   #1
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
turbo/exhaust mani gasket
is the stock one good or is there an upgrade for this? also can you use the one from a z32? thanks.
KoukiMonsta is offline   Reply With Quote
Old 08-15-2009, 10:38 PM   #2
Sileighty_85
Sileighty_85's Avatar
yes you can use the Z32 one
I advise a full metal one though
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-16-2009, 10:10 AM   #3
KoukiMonsta
okay, so i am guessing the stock one isnt metal? i thought it was which is why i posted.
what do u guys recommend then (link?) thanks.
Old 08-16-2009, 10:27 AM   #4
Sileighty_85
well ive seen some that are a paper "type"
somthing like this
T25 Inlet Gasket (T28, GT25R, GT28R, GT28RS, GT2871R, Etc) - $14.60 : Himni Racing, Turbocharger, Turbo, Garrett, Turbo Kit, GReddy, Mazda RX-7, HKS, Apexi, TiAL, TurboXS, TurboSmart, Flange, Turbonetics, Exhaust, Intercooler, ACT, Intake
I know theres another shop somewhere that has a thicker version but i cant seem to locate it
後輪駆動車1番
1986 SR86 - 200ish
Old 08-16-2009, 11:03 AM   #5
dex
dex's Avatar
dex will become famous soon enoughdex will become famous soon enoughdex will become famous soon enoughdex will become famous soon enough
when at local Nissan dealer to replace mine and they gave me a full metal one. I doubt you need anything better... (Job is pain in the ass though)
dex is offline   Reply With Quote
Old 08-16-2009, 12:17 PM   #6
Prok0
Prok0 will become famous soon enoughProk0 will become famous soon enoughProk0 will become famous soon enough
Send a message via AIM to Prok0
If you can get the S15 multi layer, they are pretty bad ass.
Using the head/manifold s15 gasket as well as the S15 T2 gasket, never had a problem.
Also threw new hardware on everywhere to keep everything tight so that probably helped...
You can get a nice set of studs/prevailing torque nuts from autozone for like under 10$ for 8 of em, I would suggest that if your doing the gasket..They are for some chevy or ford V8 but they fit fine..
Prok0 is offline   Reply With Quote
Old 08-16-2009, 02:33 PM   #7
KoukiMonsta
okay thanks
those were the gaskets i was seeing online.
i do have this gasket but it has damage(screwdriver), and im thinking this isnt re-usable?
and also between the o2 housing and DP is rtv enough or do i need an actual gasket?
Old 08-16-2009, 03:59 PM   #8
dex
dex's Avatar
don't use that gasket... if you boost more the 7psi it's most likely going to leak soon... not worth doing the job twice..
Old 08-16-2009, 04:08 PM   #9
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
I've got a used good turbo to manifold gasket for you. If you want it let me know. PM me.
Or just go to the nissan dealer and buy a brand new one.
garagelu is offline   Reply With Quote
Old 08-16-2009, 05:46 PM   #10
Prok0
dont cheap out , but new gaskets, throw some new hardware at it, and dont deal with it again.
Pulling the turbo/manifold off is a pain in the ass and I wouldnt want to do it more then once...
I just noticed you bought angry steves old car, hows it running?
Old 08-16-2009, 06:35 PM   #11
KoukiMonsta
its running good, turbo went bad hence why im doing this but other than that not bad.
looks like ill be getting a new gasket then. and for copper exhaust mani gaskets is there a direction for them?
Old 08-16-2009, 05:50 PM   #12
TheRealSy90
TheRealSy90's Avatar
yeah i've replaced this gasket twice now and I can't figure out why it keeps failing? does 10psi really affect it that much?
Old 08-16-2009, 05:58 PM   #13
Prok0
Unless your using a shit organic gasket I dont see why it would fail, unless you have old hardware and the nuts are loosening up and causing the turbo to loosen up off the manifold
(Which happened to me once, then I put new hardware in, reused my multilayer t2 gasket and havent had a problem since)
You can see in the picture, the multilayer S15 turbine gasket and exhaust manifold gaskets that are bundled with the tomei expreme manifold kit, I think if you call up enjuku they have the part numbers written down for just the gaskets and you can order them thru enjuku.
Old 08-16-2009, 06:46 PM   #14
drifter_for_life06
drifter_for_life06's Avatar
drifter_for_life06 is making a name for him/her selfdrifter_for_life06 is making a name for him/her self
Send a message via AIM to drifter_for_life06 Send a message via Yahoo to drifter_for_life06
got all my gaskets from Enjuku. Mr. Gasket copper manifold gasket and all the rest were just OEM replacements from them. They work flawlessly
RPS13: +.020" 2871r 264's AEM EMS
http://enjukuracing.com/#_l_4s
drifter_for_life06 is offline   Reply With Quote
Old 08-17-2009, 01:00 PM   #15
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
I'm running an Expreme kit with all of the s15 mulit-layer gaskets. The stock s13 or Z32 4 bolt collector gasket works fine. I've put over 18psi to one without issues. Usually the stock gasket fails once the hardware loosens up. As for the MR.Gasket Copper, I've had it fail on me before. Without moving straight to bashing, I think its due to the copper expansion rates, but I'm no expert on thermal dynamics. I will tell you with that gasket, I have had trouble keeping the hardware on the head tight. This is why I attribute it to the differences in expansion.
Enjuku doesn't carry the multi-layer gaskets to my knowledge...
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 08-17-2009, 01:13 PM   #16
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
replace all your studs while you have it out.
clark is offline   Reply With Quote
